Atomic clocks and the speed of light
The accuracy of atomic clocks is not directly dependent on the speed of light but rather on the fine structure constant. If the fine structure constant were to change, it would affect the frequency of oscillations in atomic clocks, such as those using caesium. The oscillations occur at a defined rate of 9 billion per second, which remains constant under current definitions. Discussions suggest that the concept of the speed of light changing is not meaningful in this context. Therefore, the stability of atomic clock accuracy relies more on fundamental constants than on variations in the speed of light.
glassjester
Is the accuracy of atomic clocks in any way dependent on the speed of light?
For example, if the speed of light were to speed up slightly, would that somehow speed up the frequency of oscillations of caesium used in an atomic clock? ...or would those 9 billion (or so) oscillations occur at the exact same speed they do now (1 second, by definition)?
Science news on Phys.org
It is not really meaningful to talk about the speed of light changing. However, what you are probably actually thinking about is changes in the fine structure constant. If the fine structure constant were to change that would definitely change the frequency of an atomic clock.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
