Attempt to combine Charles and Boyles laws
  • Thread starter Thread starter johns123
    Laws
The discussion revolves around calculating the pressure of air at an altitude of 160 km, where the air density is given as 1.5 x 10^-9 kg/m^3 and the temperature is 500 K. The participants reference the ideal gas law and consider the implications of using Charles's and Boyle's laws in this context.
  • Participants explore the relationship between pressure, volume, and temperature using the ideal gas law. There is discussion about establishing ratios between values at altitude and standard conditions. Some participants question the assumptions regarding molecular mass and the application of gas laws under the given conditions.
Several participants have offered guidance on how to approach the problem, including hints about calculating moles per cubic meter and using the ideal gas law. There is an ongoing exploration of the calculations involved, with some participants expressing uncertainty about their results and the constants used.
Participants note the challenges of working with low air density at high altitudes and the potential for confusion regarding constants and units. There is also mention of the need for significant figures in the final answer.
johns123
At altitude of 160 km, the density of the air is 1.5 x 10^-9 kg/m^3
also the temp at that altitude is 500 K ( that's what it says! )
What is the pressure at that altitude?
pV = nRT and mass density of air = "rho"
the 1-values are at STP, the 2-values are at altitude
p1 = 1ATM ; rho1 = 29 kg/m^3 ; T1 = 273 K
And I don't see that either vol or temp is being
held constant, so just Boyle's or Charle's law
cannot apply alone ( in my opinion ).
I think I can establish a ratio between these values at altitude
and the same values at STP and calc the unknown p2. Do you agree?
p1 * V1 n1 * R * T1
_______ = ___________ Where the Rs cancel
p2 * V2 n2 * R * T2
so p2 = p1 [ ( n2 V1 T2 ) / ( n1 V2 T1 )
but ( n2/V2 ) / (n1/V1) should equal ( rho2 / rho1 )
giving p2 = p1 * ( rho2/rho1 ) * T2/T1
I think you are supposed to assume the air has the same molecular mass as it has near the surface (ie. M = 29 g/mol = .029 kg/mol)
At 160 km altitude you are into the thermosphere. The molecules are moving around rather quickly but not a lot of total energy due to low density.
Work out the number of moles / m3. (n/V) and then use PV=nRT to find the pressure.
AM
OK. Thanks. I'm struggling with concepts here .. a battle of definitions. I'll solve it your way and post that.
Finally, I think I understand it ( I hope )
If air density at altitude is 1.5 x 10^-9 kg/m^3 at 500K and ( your hint ) M = .29 kg/mole that gives
1.5 x 10^-9 / .29 = 5.172 x 10^-9 moles/m^3 .. which is ( your hint ) = n/V
and now use pV = nRT or p = (n/V)RT = 5.172 x 10^-9 ( 8.81 joules/molesK ) 500k ( and the units work )
so finally ( after 2 weeks ) p = 42.98 x 10^-9 pascals ( I sure hope so .. thanks )
My hint was to use M = .029 Kg/mol. Where did you get .29 Kg/mol?
The approach is correct. But where do you get R=8.81 J/mol K? And you appear to have forgotten to multiply by T. So your answer is about 4 orders of magnitude too low. Other than that...
AM
I think I need to learn to type :-) it's 8.31 J/mk. I was just copying out of my notebook. Try again.
n/V = 1.5 x 10^-9 kg/m^3 / .029 kg/mole = 51.724 x 10^-9 moles/m^3
and using p = (n/V)RT = 51.724 x 10^-9 ( 8.31 ) 500K = 214913.22 x 10^-9 pa ( I really hate this calculator )
thanks
thanks
You should round to 2 or 3 significant figures and express the answer in normalized scientific notation. But the answer is correct.
AM
Thanks Andrew. I think this one problem holds the key to a world of conversions that are left out of the books. I am using 3 books trying to learn one chapter.
