Attractive and repulsive forces from net charges
To determine the force between two objects based on their net charge, one must consider Coulomb's law, which states that the force is proportional to the product of the charges and inversely proportional to the square of the distance between them. In the case of a charged balloon and a neutrally charged wall, the balloon will induce a charge separation in the wall, leading to an attractive force. The magnitude of this force can be calculated using the effective charge of the induced polarization in the wall. The interaction is dependent on the distance between the balloon and the wall, as well as the charge value of the balloon. Understanding these principles is essential for analyzing attractive and repulsive forces in charged systems.
member 529879
How do you determine the force between two objects based on their net charge. For example, if you have a charged balloon and you know the value of that charge and the distance it is away from a neutrally charged wall, how can the attractive force between the wall and balloon be determined?
http://en.wikipedia.org/wiki/Coulomb's_law
Read this.
For there to be attraction or repulsion between two charged bodies, the basic requirement is that the bodies have a CHARGE. So what do you think will happen in case of the neutrally charged wall?
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
