Average Energy of Boltzmann Distribution
7 replies · 13K views
mamela
The question is:
Write an expression for the average energy of a set of particles obeying Boltz-
mann statistics and each having energy E = bz2, where b is a constant and
z is a variable. Hence, show that the average energy per degree of freedom
for each particle is 1
2kBT; where kB is Boltzmann's constant. You should use
the standard integrals shown at the end of the question.
You are given:
[integral from -infinity to infinity]exp(-ax2)dx = SQRT(PI/a)
and
[integral from -infinity to infinity]x2exp(-ax2)dx = (1/2)SQRT(PI/a3)
I've taken the average energy as [integral from -infinity to infinity]E.Aexp(-E/KBT)dE which gives:
[integral from -infinity to infinity]2b2z3exp(-bz2/KBT)dz by changing variable to z (dE/dz=2bz)
But this is not the standard result so I can't proceed!
Try integration by parts:
[tex]\int u\,dv=uv-\int v\,du[/tex]
where [itex]u=E[/itex] and [itex]v=-k_BT\exp\left[-E/k_BT\right][/itex]
I just tried it and ended up with -2Ab7/2
oops! I mean -2Ab^7/2.b^7/2.KB^-3/2.T^-3/2
I think your problem is two-fold:
  1. You're not using the correct formula for the average value
  2. You're putting in [itex]E=bz^2[/itex] when you don't really need to
Both points are explained a little more below
[tex]\langle E\rangle=\frac{1}{k_BT}\int_0^\infty E\exp\left[-\frac{E}{k_BT}\right]dE[/tex]
then using integration by parts from my previous post:
[tex]\int_0^\infty E\exp\left[-\frac{E}{k_BT}\right]dE=\left.-E\exp\left[-\frac{E}{k_BT}\right]\right|_0^\infty +\int_0^\infty k_BT\exp\left[-\frac{E}{k_BT}\right]dE[/tex]
The first term on the right is zero at the limits, so then
[tex]\langle E\rangle=\frac{1}{k_BT}\int_0^\infty k_BT\exp\left[-\frac{E}{k_BT}\right]dE=k_BT[/tex]
Where does the additional term 1/KBT come from?
That appears to work but I need to show the average energy is (1/2)KBT.
[tex] \int_{0}^{\infty}{E^{n} \, \Exp\left[-\frac{E}{k \, T}\right] \, dE} = (k \, T)^{n + 1} \, \int_{0}^{\infty}{x^{n} \, e^{-x} \, dx} = \Gamma(n + 1) \, (k \, T)^{n + 1}[/tex]
[tex] \Gamma(n + 1) = n![/tex]
The [itex]1/k_BT[/itex] comes from the normalization constant A that you have in your first post.
If you are requiring that to be the answer then I suppose that [itex]z[/itex] is a speed? If that's the case, then
[tex]f(E)=A\exp\left[-\frac{E}{k_BT}\right]=\sqrt{\frac{b}{\pi k_BT}}\exp\left[-\frac{bz^2}{k_BT}\right][/tex]
Then the average speed-squared is
[tex]\langle z^2\rangle=\sqrt{\frac{b}{\pi k_BT}}\int_{-\infty}^\infty z^2\exp\left[-\frac{bz^2}{k_BT}\right][/tex]
You can then use your second given equation and you should be able to get the answer:
[tex]\langle z^2\rangle=\frac{k_BT}{2b}\rightarrow\langle E\rangle=b\langle z^2\rangle=\frac{1}{2}k_BT[/tex]
