Calc Average Total Force for 50kg Cyclist on 1km Hill
  • Thread starter Thread starter jenc305
    Average Force
The discussion focuses on calculating the average total force required for a 50kg cyclist to ascend a 1 km hill at a constant speed of 20 km/hr (5.56 m/s). Participants clarify that since the cyclist maintains a uniform speed, acceleration is zero, and thus the net force acting on the cyclist is also zero. The primary forces to consider are the gravitational force and frictional force acting parallel to the hill, which can be calculated using the equation f = mg, where g = -9.8 m/s², and the angle of the hill derived from the Pythagorean theorem.
  • Understanding of Newton's laws of motion
  • Familiarity with gravitational force calculations (f = mg)
  • Basic knowledge of trigonometry (Pythagorean theorem)
  • Concept of frictional force and its role in motion
  • Learn how to calculate forces on inclined planes using trigonometric functions
  • Study the concept of work done against gravity in physics
  • Explore the relationship between speed, acceleration, and net force in physics
  • Investigate the effects of friction on motion in different terrains
Physics students, cycling enthusiasts, and anyone interested in understanding the dynamics of motion on inclines and the forces involved in cycling performance.
jenc305
How do I go about solving this equation. Thanks.
A 50kg cyclist, pedaling at 20 km/hr = 5.56m/s, climbs a 1 km hill in 30mins (.556m/s). What average total force on her bicycle is required for her to make it up the hill in this amount of time?
I know that I have to find the acceleration to calculate the force, since N=(kg*m)/s^2. What equation would I use to accomplish this?
I think you left something out of the statement of the problem. Given the information you provided the cyclist could just as well be coasting on level ground without expending any energy.
As the speed is uniform how could acceleration be there.
Force required to make it up the hill is equal to the force to overcome friction, if mentioned, work done against the gravity.
{i am not 100% sure but most probably it's true}
Interesting...that is all the information I was given.
So I wouldn't calculate acceleration since the cyclist is working against gravity.
If I used f=mg (g=-9.8m/s^2)would that determine the total force?
Oh, the "1 km" hill must refer to the HEIGHT of the hill! If that's the case then you can do it! Basically, how much energy is required to raise the cyclist through 1 km?
ooh..ok
So I would use the pythagorean theorem to find the angle and then use equation a=g sin (theta). Once I have found "a" then I can calculate f=ma.
Am I on the right track?
Thanks!
This question is poorly formulated. Since the bike is not accelerating, the total force on it must be zero. But I'm guessing that they want you to figure out the frictional force parallel to the hill that the ground must exert on the bike tires to overcome gravity. Find the angle of the hill and the component of the weight down the hill. That's what the friction must overcome.
You may want to ask your instructor for clarification.
