Finding the Axle Force on a Pulley System
  • Thread starter Thread starter needphyshelp
    Axle Pulley
The discussion focuses on calculating the axle force exerted on a pulley system involving a 12.0 kg box and a 5.00 kg weight connected by a wire over a frictionless pulley. The pulley is a uniform solid disk with a mass of 2.00 kg and a diameter of 0.500 m. The tension in the wire was determined to be 32.6 N and 35.4 N, with a linear acceleration of 2.72 m/s². The key conclusion is that the axle force must balance the tension forces, ensuring the net force on the pulley is zero.
  • Understanding of Newton's laws of motion
  • Knowledge of tension in a pulley system
  • Familiarity with rotational dynamics and torque
  • Basic principles of force equilibrium
  • Study the concept of torque in rotational dynamics
  • Learn how to apply Newton's second law to rotational systems
  • Research methods for calculating forces in pulley systems
  • Explore the relationship between linear and angular acceleration
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of pulley systems and force analysis.
needphyshelp
A 12.0kg box resting on a horizontal, frictionless surface is attached to a 5.00 kg weight by a thin, light wire that passes over a frictionless pulley. The pulley has the shape of a uniform solid disk of mass 2.00 kg and diameter 0.500 m. After the system is released, find the horizontal and vertical components of the force that the axle exerts on the pulley.
F=ma (?)
I have already calculated the tension in the wire on both sides of the pulley (x =32.6N and y=35.4 N) and the linear acceleration which equals 2.72 m/s2. I know that this question has been asked previously, but I still don't understand what the force exerted on the pulley by the axle is.
Am I just trying to find Fx=m (alphax) and Fy=m(alpha y)?
Hint: Since the center of mass of the pulley doesn't move, the net force on the pulley must be zero.
But how would I calculate the components of the force acting on the pulley? I know nothing about the axle, and it can't be just the tensions on each side because their net force is not zero.
All you have to know is that the force that the axle exerts on the pulley must exactly balance the tension forces on the pulley. It's not the tensions that add to zero, it's the tensions plus the axle force that must add to zero. And if the net force is zero, all components of the net force must be zero.
  • · Replies 66 ·
