- #71
rcgldr
- 8,855
- 632
Jeff Reid said:I wasn't aware that the term "tail stall", isn't the same as a true elevator stall.
No problem, my fault for not looking up tail stall before posting. I never heard the term "tail stall" before, I have read a lot about aerodynamics (I also fly radio control gliders). I was aware of how icing can badly affect airfoil shapes, but was totally unaware that deploying flaps at speed, combined with icing effects, could result in tail stall. After looking up more web pages about this, some aircraft are subceptible to tail stall while others aren't (those others still have icing issues, but not the pitch down issue related to tail stall).Danger said:That would certainly explain the original disagreement. My apologies if I seemed condescending.
Anyway, it doesn't appear that "tail stall" was an issue. The pilot might have mistakenly though the aircraft was in a "tail stall" due to the auto pilot pitching the nose down and shutting off, and pulled back on the yoke in what is reported at a 2G manuever. The news is reporting that the aircraft pitched up 31 degrees (not down) and hitting a 2 g peak (1 g of this is gravity related). It's also possible that the pilot was trying to avoid a mid-air collision with what might have appeared to be another aircraft.
Aircraft pitched up 31 degrees, rolled 106 degrees, tail icing (tail stall) not an issue for this aircraft, but it was on the previous type of aircraft that that pilot had flown a possible reason that the pilot pitched the nose up so much. There's a animated mulitmedia link in the second photo on this web page describing what happened (airspeeds aren't known yet and I don't know why):
http://www.nytimes.com/2009/02/19/nyregion/19crash.html?hp
This web page includes more info, including some air speeds:
http://buffalopundit.wnymedia.net/blogs/archives/8070
It's really too soon to tell. Pitching the nose up 31 degrees from a nose down condition and pulling 2g's seems extreme, causing me to wonder if some type of mechanical failure was involved.
