Band diagram of pn-junction diode at low temperature
The discussion revolves around the band diagram of a pn-junction diode at very low temperatures, specifically addressing the implications of complete dopant ionization freeze-out on the device's characteristics. Participants explore theoretical aspects of semiconductor physics, including built-in potential and Fermi level positioning under these conditions.
  • One participant questions whether the band diagram at low temperatures would resemble that at room temperature, given the complete freeze-out of dopant ionization.
  • Another participant suggests that the band structure may not change significantly, but raises the issue of whether low-temperature physics can still be described using an independent electron model.
  • A participant expresses concern about describing the built-in potential in the absence of mobile charge carriers, questioning how this affects the analysis of the diode.
  • There is a discussion about the behavior of the pn-junction diode when cooled, with emphasis on the lack of mobile carriers and the implications for the Fermi level and band diagram.
  • One participant notes that while carriers may freeze out, ionized impurities remain in the space-charge region, which could influence the overall behavior of the diode.
  • Another participant clarifies that the Fermi level does not necessarily move towards mid-gap when carriers freeze out, referencing the Fermi-Dirac statistics to explain this phenomenon.
  • There is a question about the feasibility of drawing a band diagram at absolute zero and whether equilibrium can be achieved under complete freeze-out conditions.
Participants express differing views on the implications of low temperatures for the band diagram and built-in potential of the pn-junction diode. There is no consensus on how to approach the analysis under these conditions, and multiple competing perspectives are presented.
Participants highlight limitations related to assumptions about ionization, the behavior of carriers at low temperatures, and the applicability of standard semiconductor physics models in this context.
sunnyleekr
Hi
What could be the band diagram of pn-junction diode at very low temperature where dopant ionzation is completely frozen out?
Would it still be like the band diagram at room temperature?
I don't think that the band structure per se will change very much. It is more a question whether the physics at low temperatures can still be described within an independent electron picture.
Thank you for the reply but if the band diagram doesn't change much, how can we describe the built-in potential since there is no mobile(ionized) charge present?
Ok, so you are asking whether it makes a difference to bring two junks of p and n doped semiconductor at room temperature or at low temperature?
I was thinking of cooling a diode.
We usually learn semiconductor physics based on the fact that dopant ionization is present.
The simplest doped device we can think of will be pn-diode. And we know analytically what the depletion width, built-in potential and band diagram will be with given temperature and doping (Na/Nd).
But let's think of the behaviour of such device at very low temperature where there are absolutely no mobile carriers (extra charge from donor/acceptor is not at all ionized).
Where will be the fermi level of n/p-type semiconductor?
Can we draw band diagram if we attach p and n type semiconductor to build a pn diode?
What is the built-in potential of pn-diode?
No mobile charge but can we still apply room temperature analysis?
These are the questions I have.
The carriers freeze out on each side of the space-charge region. Inside the space-charge region, carriers are "pushed out" by the built-in field, so you still have ionized impurities.
At the energy where ne=1/2. In semiconductor physics, the Fermi level is really the chemical potential term in the Fermi-Dirac statistics. The Fermi level does not move towards mid-gap when carriers freeze out (I think that's what you're thinking). Carriers freeze out because of the exp{(E-EF)/kT} term in the denominator of the FD statistics.
If you do it at T->0K? Well, in the degenerate case, you will never have complete freeze-out anyway. But if there was complete freeze-out, you would probably never reach equilibrium. Remeber that the "Fermi level must be the same evrywhere" condition applies to equilibrium.
