Banked roads -- circular motion and gravitation
The discussion revolves around a physics problem involving banked curves, circular motion, and the coefficient of static friction for a car traveling at different speeds on a banked road. The original poster attempts to determine the necessary coefficient of static friction to prevent skidding when the car's speed increases.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the components of forces acting on the car, including normal force and friction. There are attempts to isolate variables and derive equations related to the forces involved. Some participants question the steps taken in the calculations and suggest corrections to the equations used.
The discussion is ongoing, with participants providing feedback on each other's approaches and calculations. Some guidance has been offered regarding the manipulation of equations, and there is acknowledgment of the need to cancel mass from the equations. Multiple interpretations of the problem are being explored, but no consensus has been reached on the final solution.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is an emphasis on ensuring that the calculations align with the physical principles of motion and friction.
MPat
If a curve with a radius of 88m is perfectly banked for a car traveling at 75km/h, what must be the coefficient of static friction for a car not to skid when traveling at 95 km/hr
75km/h = 20.8m/s
95km/h = 26.4m/s
Fr=mv^2/r
Fr=centripetal force
m = mass
r = radius
v = velocity
Fn= normal force
Ffr= force of friction (Us*Fn)
g = gravitational acceleration
Us = coefficient of static friction
Horizontal component
sinθFn=mv^2/r Eq 1
Vertical component
cosθFn=mg
Fn=mg/cosθ Eq 2
Sub eq 2 into 1
sinθ (mg/cosθ) = mv^2/r (sinθ/cosθ = tanθ)
tanθ mg = mv^2/r
m cancels out
tanθ = v^2/gr
θ = arctan 20.8^2/9.8*88
θ = 26.6 degrees
Am I right up to there?
Now for the second part of the question. Solving for Us.
See diagram for force of friction and horizontal and vertical components
Vertical component
cosθFn - sinθFfr - mg = 0 ( there is no vertical displacement)
Solve for Fn
Fn= (sinθFfr + mg)/cosθ
sinθFn + cosθFfr = mv^2/r
Sub Fn from above
sinθ ((sinθFfr + mg)/cosθ) + cosθFfr = mv^2/r
From here I am unable to isolate Ffr, or cancel out the mass... Help!
Without going through your whole solution, one thing I noticed is that when you solve for Fn, you divided mg by cosθ, but you forgot to divide the first term by cosθ.
EDIT: Also, I don't know why you are not able to isolate Ffr.
Under vertical component?
Vertical component
cosθFn=mg
Fn=mg/cosθ Eq 2
I divide both sides by cosθ here on the left side cosθ cancels out and on the right it becomes mg/cosθ
Is this what you were referring to?
Solve for Fn
Fn= sinθFfr + mg/cosθ
Should be:
cosθFn = sinθFfr + mg
cosθFn/cosθ = (sinθFfr + mg)/cosθ
Fn = sinθFfr/cosθ + mg/cosθ
TomHart said:
Should be:
Ok that correcting that I get the following
sinθ (sinθFfr/cosθ + mg/cosθ) + cosθFfr = mv^2/r
=sinθtanθFfr + tanθmg + cosθFfr = mv^2/r
= Ffr(sinθtanθ + cosθ) + tanθmg = mv^2/r
Ffr = (mv^2/r - tanθmg)/(sinθtanθ+cosθ)
Even if I isolate Ffr here, m is unknown and I haven't been able to cancel it out...
MPat, I see your point. And I wish I had time right now to sort this out, but I have to leave right now. I worked out the problem and, as expected, the mass does cancel out at some point. But I don't have time to compare my solution with yours. I will try to look at it later on tonight. But hopefully, someone will beat me to it.
Thanks for your help! Much appreciated.
$$F_n\cos \theta-F_{fr}\sin \theta=mg\tag{1}$$
$$F_n\sin \theta+F_{fr}\cos \theta = m\frac{v^2}{r}\tag{2}$$
Multiply Eqn. 1 by ##\cos \theta## and Eqn. 2 by ##\sin \theta##. Then add them together. What do you get?
Multiply Eqn. 2 by ##\cos \theta## and Eqn. 1 by ##\sin \theta##. Then subtract the result from Eqn. 1 from the result from Eqn. 2. What do you get?
MPat said:
Solve for Fn
Sub Fn from above
MPat, I think your problem starts when you "solve for Fn". Mathematically, you did it right. But you really still have another Fn term on the right-hand side of that equation because the friction force Ffr is proportional to the normal force Fn. You should make that substitution BEFORE you solve for Fn.
@MPat
If you had followed the simple linear equation elimination approach I indicated in post #8, you would have immediately obtained:
$$F_n=mg\cos \theta+m\frac{v^2}{r}\sin \theta$$
$$F_{fr}=m\frac{v^2}{r}\cos \theta-mg\sin \theta$$
Chestermiller said:
@MPat
GOT IT!...answer is Us = 0.22
I confirm that (0.216).
  • · Replies 19 ·
  • · Replies 21 ·
