Deriving Mass of Xi Using Formula
What I wrote was the fraction of the total wave function. To get the probability, square the amplitudes.
kcirick
54
I am trying to derive the mass of [itex]\Xi[/itex] using the formula:
[tex]M\left(baryon\right)=m_1 + m_2 + m_3 + A' \left[\frac{S_1 \cdot S_2}{m_1 m_2} +\frac{S_1 \cdot S_3}{m_1 m_3} + \frac{S_2 \cdot S_3}{m_2 m_2\3}\right][/tex]
We have:
[tex] S_1 \cdot S_2 + S_1 \cdot S_3 + S_2 \cdot S_3 = \frac{\hbar^2}{2}\left[j\left(j+1\right)-2/4\right] = -3/4 \hbar[/tex] for octet
and also:
[tex]\left(S_u+S_d\right)^2 = S_u^2 + S_d^2 + 2S_u \cdot S_d [/tex]
What I don't get it the last equation. In the case of [itex] \Sigma [/itex], is equal to [itex]2\hbar^2[/itex] because the isospin is 1 (and therefore [itex]S_u \cdot S_d = \hbar^2 /4[/itex]. Following the pattern, since the isospin of [itex]\Xi[/itex] is 1/2, I tried to figure out [itex]S_s \cdot S_s[/itex] which is needed, since the quark content for [itex]\Xi[/itex] is uss. I got [itex] S_s \cdot S_s = -3/8\hbar^2[/itex] which doesn't give the right answer.
The right answer should be:
[tex]M_\Xi = 2*m_s + m_u + \frac{\hbar^2}{4}A'\left(\frac{1}{m_s^2}-\frac{4}{m_u m_s}\right) [/tex]
Can someone help me? thanks!
s1.s2=+1/4 for S=1, and -3/4 for S=0.
For the s-s pair, this gives s1.s2=+1/4.
for the two s-u pairs you have to recouple the spin states.
The result is that each s-u pair is 1/4 spin 1, and 3/4 spin 0.
Using those factors gives the right answer.
This was first done in PR 154 (1967) 1608.
Thanks for the reply.
When you say for S=1 or S=0, what does that correspond to? I thought it was just an isospin of the particle (so 1/2 for [itex]\Xi[/itex] and 0 for [itex]\Lambda[/itex]), but I guess that's not the case. In the text (Griffiths), he says something about spins being "parallel" in the decuplet case. What does that mean exactly? What about in octet case?
We have:
and also:
in what section is that covered in griffiths? I think I have the book around and could look it up.
The S's in the formula are the *spins* of the particles, not the Isospin. Spin and isospin are totally different concepts.
This is from Griffiths "Introduction to elementary particles", chapter 5: bound states. pp 180 - 184.
the spins of the quarks (u,d,s) are all 1/2, so [itex]\left(S_u + S_d \right)^2 [/itex] should aways be [itex] 2\hbar[/itex], but in the text it says it is equal to 0 for [itex]\Lambda[/itex] (it says it is equal to [itex]2\hbar[/itex] for [itex]\Sigma[/itex] though...)
They all have spin 1/2, that's true, but that does not mean that [itex]\left(S_u + S_d \right)^2 [/itex] is necessarily [itex] 2\hbar[/itex]! Two particles with a spin of 1/2 may either be in a total spin S=0 or a S=1 state. As Achuz said, if they are in the S=0 state, then [itex]\left(S_u + S_d \right)^2 = 0 [/itex] (in which case [itex]S_u \cdot S_d = -3/4 \hbar^2 [/itex]) whereas if they are in the S=1 state, [itex]\left(S_u + S_d \right)^2 = 2 \hbar^2 [/itex] (in which case [itex]S_u \cdot S_d = 1/4 \hbar^2 [/itex])
So, how do you know if they are in S=0 state or S=1 state? Is this where isospin comes in (Griffiths mentioned this, but I didn't know what he was talking about)?
The Ispin is irrelevant here. I trhink that PR article would be easier clearer on this than Griffiths. Each pair of quarks adds their spin to 12+1/2=0 or 1.
Two identical quarks (like s-s) must add to spin one, for which s1.s2=+1/4.
The difficulty comes for two different quarks (like s-d).
Then their spin addition can give 1 or 0. For spin zero, s1.s2=-3/4.
YOu can show that the s-d pair has probability 1/4 of being in the spin one state and probabilty 3/4 of being in the spin zero state. This should be enough info to get all the octet masses.
The decuplet has spin 3/2, so each quark pair is in the spin one state.
Griffiths can't be followed because he tries to simplify, and leaves out the physics.
Achuz said, "The difficulty comes for two different quarks (like s-d).
YOu can show that the s-d pair has probability 1/4 of being in the spin one state and probabilty 3/4 of being in the spin zero state."
Why do you say that?
I thought the probability of being in a state with spin 1 is higher and should be 3/4 instead?
Thanks ^_^
The Xi total spin 1/2 wave function is (ssu)[2aab-aba-baa]/sqrt{6},
where a is for spin up and b for spin down. This has the first two (ss) quarks in a spin one state. If you recouple the spin states, this combination can be written as (ssu){[sqrt{3}/2][a(ab-ba)/sqrt{2}]-[1/2][2baa-aab-aba]/sqrt{6}}.
The first term has the 2nd and 3rd (su) quarks in a spin zero state and the second term has them in a spin one state.
You can read the probabilities as 3/4 and 1/4.
Hi Meir, thanks for the response again...I kind of know what you mean...
One more question though, when you said "The Xi total spin 1/2 wave function is (ssu)[2aab-aba-baa]/sqrt{6}", how did you obtaint his result?
Here's what I think:
Xi is a spin 1/2 particle and one should use EQ 5.113. However applying that equation doesn't seem to allow me to get what u got. Any comments?
thx
joe
Oh Hi Meir again, sorry to bother you again ...
you've mentioned that the original paper that talks about baryon mass estimation is found in Physics review. I tried finding it yesterday and failed. I'd like to take a look at it. Do you have it? Would you mind sending it to me?
My email : joechien0218@yahoo.com
Thank you so much for your help! You are a good person!
thx
joe
I don't have Griffiths, but my guess is that he oversymmetrizes the wave function, which can make it quite complicated.
The first two quarks in ssu are identical, so they must be in a spin 1 state.
This gives the spin addition 1/2 + 1/2 +1/2 =[1] + 1/2 = 1/2, which is the spin wave function I gave. This will be clearer in a PR 172(1968)1807 paper I will send you. I find it amusing that the quark model was better understood 40 years ago than it is today.
I will email the pdf of another PR paper I just got off PROLA on the web.
The first paper I mentioned does not go as much into details as this one:
PR 171(1968)1807. The paper is too long to upload here.
Actually the first paper to use the s_1.s_2 interaction for hadrons was by Sakharov in 1966, then a 1975 paper by deRujula, Glashow, and Georgi deduced the 1/m_1m_2 from QCD..
Related to Deriving Mass of Xi Using Formula
1. How do you derive the mass of Xi using the formula?
The mass of Xi can be derived using the formula m = p / v, where m is the mass, p is the momentum, and v is the velocity. This formula is based on the principle of conservation of momentum.
2. What is the significance of deriving the mass of Xi?
Deriving the mass of Xi is important in understanding the properties and behavior of this subatomic particle. It allows us to study its interactions with other particles and its role in various physical processes.
3. What factors affect the accuracy of the derived mass of Xi?
The accuracy of the derived mass of Xi can be affected by experimental errors, uncertainties in the measurement of momentum and velocity, and the precision of the instruments used.
4. Can the formula for deriving mass of Xi be applied to other particles?
Yes, the formula m = p / v can be applied to any particle, as long as the momentum and velocity are known. However, the specific values for p and v will differ for each particle.
5. How does the derived mass of Xi compare to its actual mass?
The derived mass of Xi is an approximation based on the measured values of momentum and velocity. It may not be an exact match to the actual mass of the particle, but it should be close if the measurements are accurate and precise.
  • Linear and Abstract Algebra
  • Quantum Physics
