Base Diameter of a standing pole
  • Context: High School
  • Thread starter Thread starter rateesh
    Base Diameter Pole
The minimum base diameter of a standing pole, whether cylindrical or cubic, is crucial for stability and is influenced by the pole's height and the forces acting upon it. A taller pole requires a larger base area to counteract leverage and applied forces. The structural integrity of both the pole and the ground it is buried in plays a significant role in determining the necessary base diameter. Understanding these relationships is essential for ensuring that poles remain upright under various conditions.
  • Basic understanding of physics principles related to leverage and stability
  • Knowledge of structural engineering concepts
  • Familiarity with the properties of different pole shapes, such as cylindrical and cubic
  • Experience with soil mechanics and ground stability
  • Research the principles of leverage in structural engineering
  • Learn about the stability requirements for different pole shapes
  • Study soil mechanics and its impact on buried structures
  • Explore calculations for determining the base diameter of poles under various loads
Engineers, architects, construction professionals, and anyone involved in designing or installing poles for various applications will benefit from this discussion.
rateesh
What should be the minimum base diameter of a 1 meter cylindrical pole ?
What should be the minimum base diameter of a 1 meter cubic pole ?
how are these computed ?
Does length of the pole impacts the base diameter ?
I don't understand. Cubic pole? Base? Minimum diameter? 1-meter diameter pole?
I think you'll get more answers if you elaborate a little.
here is what i wanted to find out:
1. Does the base area of a pole has any impact on it to stand upright?
2. What is the relation between the length of the pole against the base area ?
Basically, the taller it is, the more area the base must cover. In practicality, though, they are usually just buried to a sufficient depth to ensure stability.
How much cross load will the pole experience? In a vacuum you could probably have a 100' bamboo fishing rod balanced on it's end with no problem. But not in an underwater tidal zone...
Good point, Schip.
It essentially comes down to leverage. The base must be sufficient in or opposed to the same direction as an applied force to counteract that force. If the latter, the weight of the base is critical. If the former, it must be long enough without regard to weight. In the case of a buried pole, the ground becomes the base, and the structural integrity of both it and the pole are the determining factors.
That's still not a complete answer, but I hope it clarifies things a bit.
Thanks Danger & schip666!, your answers did bring in some understanding. This is a "Just to know" question, but am curious to crack the equation/function/theory behind it. any direction is appreciated. May be i will try to post an image about it in the future.
  • · Replies 30 ·
