Baseband Signal Processing and Digital to Analog Converters
This discussion focuses on the role of Digital to Analog Converters (DACs) in transmitters within the context of baseband signal processing and digital modulation. It clarifies that while digital modulation generates an analog signal, DACs are essential for transforming digital signals into analog format suitable for wireless transmission. The conversation emphasizes the necessity of DACs despite the presence of analog signals post-modulation, highlighting the complexities of signal processing in communication systems.
  • Understanding of baseband signal processing concepts
  • Familiarity with digital modulation techniques
  • Knowledge of Digital to Analog Converter (DAC) functionality
  • Basic principles of wireless communication systems
  • Research the role of Intermediate Frequency (IF) in communication systems
  • Explore the architecture and design of Digital Signal Processors (DSPs)
  • Learn about various digital modulation schemes and their applications
  • Investigate the impact of DAC performance on signal integrity in wireless transmission
Engineers and technicians involved in wireless communication, signal processing specialists, and anyone interested in the intricacies of digital modulation and DAC applications in transmitters.
SriHarsha Korada
Hi Guys,
I have a question on the need for Digital to analog converters in Transmitters. To elaborate bit further:
1) Because of the advantages of the Digital signals, most go the signal processing in wireless communications is performed in baseband. But my question is: Since digital modulation is also a part of baseband processing, how can we still say its baseband as a carrier signal (which has high centre frequency) is used for modulation?
and
2) The output of baseband processing block In the transmitter side, is given to Digital to Analog converter in order to transform the digital signal to analog signal that can be sent over the wireless Channel Here my question is: Anyway due to to digital modulation, analog signal is present at the output of Modulation block and why still the point of DAC?
Even though, these questions seem basic, I need some explanation on this stuff. Hope to hear some valuable answers.
BR,
Sri
A digital signal processor is usually designed around a particular clock frequency, which would probably not be related to the wanted transmit carrier frequency. As with nearly all comms processes (analogue or digital) it is usual to produce a standard IF (analogue intermediate frequency) signal with suitable spectrum filtering which is mixed down or up to the required carrier frequency. The aggravation of making a DSP unit that would work at all carrier frequencies would be just too great.
So, you mean to say that the carrier frequency being used at digital modulator is some kind of Intermediate frequency? Even in that scenario also, the output would be analog in nature. But again why DAC?
Most likely this can only be answered by an "old timer". I am making measurements on an uA709 op amp (metal can). I would like to calculate the frequency rolloff curves (I can measure them). I assume the compensation is via the miller effect. To do the calculations I would need to know the gain of the transistors and the effective resistance seen at the compensation terminals, not including the values I put there. Anyone know those values?
12K
