Basic Capacitors: What Happens When a Thick Slab is Inserted?
  • Thread starter Thread starter michael650
    Capacitors
Inserting a thick slab of metal between the plates of a parallel-plate capacitor, while keeping it parallel and not in contact, alters the capacitance by effectively creating two capacitors in series. The electric field inside the metal slab becomes zero due to charge redistribution, which cancels any external electric field. Consequently, the capacitance can be calculated by considering the two gaps created on either side of the slab. This configuration results in a change in the overall capacitance value, as the system now behaves differently than a single capacitor. Understanding these principles is essential for grasping the underlying physics of capacitors.
michael650
The question I had was more qualitative than quantitative, but I always preferred to understand concepts in both ways clearly. Can someone explain what happens to the capacitance of parallel-plate capacitor when a thick slab of metal is inserted between the plates, parallel to them but not in contact with them? I'm having trouble going through the algebra of it all.
~~Thanks!
hi michael650! :smile:
the https://www.physicsforums.com/library.php?do=view_item&itemid=6"
the electric field E is zero inside the metal (because it's a conductor, and the charges rearrange themselves to cancel out any external field), and D0 in the two gaps …
so the capacitance is … ? :smile:
(of course, you could just say that it's now two capacitors in series, with the same charge :wink:)
on the metal slab free charge would come to the surface to make the E field inside the slab 0 since it is a conductor . Tiny tim submitted his when i was typing this .
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
