Understanding the Concept of 'Ground' in Circuit Connections
  • Thread starter Thread starter bmed90
    Circuits
In circuit connections, "ground" refers to a reference point for voltage, typically considered to be zero volts. There are two main types of ground: "circuit ground," a local reference, and "earth ground," which is physically connected to the Earth. The concept of signal ground can vary, as it can be any node in the circuit, emphasizing that voltage is measured between two points. Practically, ground nodes are usually linked to the equipment chassis and ultimately to earth ground through the power supply. Understanding the context of different ground types is crucial, as various circuits may have multiple grounding schemes that affect their operation.
bmed90
Greetings,
When connecting a circuit what does it mean when someone refers to the "ground'. Like for example, when someone says, "ok, we are connected to ground". You know? That is the sort of thing I am talking about.
There are two kinds of ground. "Circuit ground" which is just a local reference that is taken to be zero volts, and "Earth ground" which IS zero volts and is literally connected to the Earth.
One of the things that drives students crazy is the concept of signal ground. It literally can be any node in the circuit at all because the concept of voltage only makes sense as a measurement BETWEEN two nodes.
In practice, the "ground" node is usually always eventually connected to the chassis of the equipment you're using. Then it is connected finally to "earth ground" as phinds mentioned through the power supply.
Ground just means the 0 volt point. For example, in a single positive supply system, the power supply connects between +V and ground. Everything gets current from +V and returns it through ground.
Also - voltages are all relative - so the ground helps define "relative to what?" However grounding is its own specialty - and complex systems can have multiple grounds, for each type of circuit - confusing yes, so calling something "ground" without context (chassis, signal, DC supply, AC supply, RF - etc) - is almost meaningless - they each fundamentally mean the same thing - but how they are constructed, best practices as well as their purpose and effect on the operation of the circuit can be quite different.
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
  • · Replies 19 ·
11K
11K
