Basic Expected Value Problem (probability)
The discussion revolves around a problem in probability concerning expected values and variance. The original poster presents a function involving a polynomial and seeks to understand how to compute its expected value given the expected value and variance of a random variable.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the relationship between expected value and variance, specifically how to compute the expected value of a polynomial function. There is confusion regarding the distinction between E(X^2) and E(X)^2, with several participants attempting to clarify these concepts.
The discussion is active, with participants providing insights into the relationships between expected values and variance. Some have offered guidance on using the variance formula to find E(X^2), while others are questioning the original poster's understanding of the terms involved.
There is an ongoing confusion regarding the definitions and calculations of E(X^2) and E(X)^2, as well as the application of variance in this context. The original poster is also grappling with the transition from examples involving discrete scenarios to a polynomial function.
shawn87411
E[X]=2
Var(X)=3
Find E[4+4x+x^2]
I'm just confused what its asking. The expected value of this function is 2 so the average of it is 2 and the variance is how much it varies which is 3? Every example I have for expected values is related to an example such as cards, not just a polynomial
Var(X)=E(X^2-E(X)^2). Just solve that for E(X^2). Then you can find E of the quadratic.
Is the E(X^2-E(X)^2) = E(2^2-(4+4x+X^2)^2)?
No... Var(X)=3=E(X^2)-E(X)^2. E(X)=2. What's E(X^2)?? E(4+4X+X^2)=E(4)+E(4X)+E(X^2). Right? Etc. Use the linearity properties of 'E'.
I think I'm mixing up the terms E(X^2) and e(X)^2. Which one is E[X]=2?
So E(X^2)=E(4)^2+E(4x)^2+(x^2)^2?
E(X)^2=4, since E(X)=2.
Right but what's the difference between E(X^2) and E(X)^2?
Is E(X^2)=E(4^2)+E(4x^2)+E((x^2)^2) with x=2?
No! E(X^2) is not the same as E(X)^2. They aren't directly related to each other. The only way you can find E(X^2) from the information you are given is to use Var(X)=3.
Var(X)+E(X)^2=E(X^2)
3+4=7=E(x^2)
Then use the fact that E(4+4X+X^2)=E(4)+E(4X)+E(X^2).
3+4=7=E(x^2)
Yes, that's it.
13K
