How Do You Calculate the Decay Rate of C14 with a Given Half-Life?
  • Thread starter Thread starter KevinMWHM
    Exponential Ln
The decay rate of Carbon-14 (C14) is calculated using the formula ekt, where the half-life is 5230 years. The correct decay constant (k) is derived from the natural logarithm of 2 (ln2), resulting in a negative value for k, which reflects the decreasing quantity of C14 over time. The discussion emphasizes the importance of understanding the behavior of exponential functions in decay scenarios, specifically that a positive k would incorrectly suggest an increasing quantity. The key takeaway is that for decay processes, k must always be negative.
  • Understanding of exponential functions and their properties
  • Knowledge of natural logarithms, specifically ln2 and ln0.5
  • Familiarity with the concept of half-life in radioactive decay
  • Basic principles of differential equations
  • Study the derivation of decay constants in radioactive materials
  • Learn about the applications of differential equations in modeling decay processes
  • Explore the implications of negative versus positive growth rates in exponential functions
  • Investigate other radioactive isotopes and their decay rates for comparative analysis
Students preparing for differential equations, physicists, chemists, and anyone interested in understanding radioactive decay and its mathematical modeling.
KevinMWHM
Doing some self prep for Diff EQ starting next week.
Determine the decay rate of C14 which has a 1/2 life of 5230. Using e^kt as a function,
I solve using k5230=ln.5 which gives the obvious answer of negative what I want. How do I know to use the reciprocal (ln2) other than to "just know" I want the positive k value? What if I'm looking for something where I may want a negative but don't know it? Will there be such an instance?
-thx
trust your answer bro. if your function is e^kt then you do want k to be negative. A nice way to check is to think about the graph of e^kt and what it looks like for k negative and k positive. And keep in mind the question is about decay, so then which graph makes most sense?
-thx
Your intuition is off. You either want ##e^{kt}## with ##k < 0## or ##e^{-kt}## with ##k > 0##.The quantity ##Q = Q(t)## of C14 must be a decreasing function of t, since the substance is decaying. If you had ##Q = e^{kt}## with ##k > 0## then Q would be increasing without bound, so the amount of C14 would grow so much over a long time as to swallow up the whole earth---not what you want.
9K
  • · Replies 0 ·
15K
