MHB Basic Inequality Prove: $A\leq B\wedge B\leq A \Rightarrow A=B$
  • Thread starter Thread starter solakis1
    Inequality
The discussion focuses on proving the statement that if A is less than or equal to B and B is less than or equal to A, then A must equal B. It references the trichotomy law, which asserts that for any two numbers A and B, one of three conditions must hold: A is greater than B, A is less than B, or A equals B. The participants clarify that since A is less than or equal to B, A cannot be greater than B, and since B is less than or equal to A, A cannot be less than B. The equivalence of the trichotomy law to the expression A < B or B < A or A = B is also questioned. The discussion emphasizes the logical structure underpinning the proof of equality based on the given inequalities.
solakis1
Prove:
$A\leq B\wedge B\leq A\Rightarrow A=B$
Mathematics news on Phys.org
Trichotomy: Given numbers A and B, one and only one must be true:
1) A> B
2) A< B
3) A= B
Since [math]A\le B[/math], A> B is not true.
Since [math]B\le A[/math], A< B is not true.
Is the trichotomy law you are using Equivelant to the following:
$A<B\vee B<A\vee A=B$
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
