Basic Question about Centripetal Force
The discussion centers on calculating the gravitational acceleration required to keep satellites in orbit around a hypothetical planet with a radius of 25 picometers. The satellites have an inertial velocity of 1.8504e10 meters per second, and the key equation mentioned is a=v^2/r, where r is the total distance from the planet's center to the orbiting satellites. The poster expresses confusion about the relationship between gravitational force and orbital mechanics, particularly regarding the effects of acceleration and mass. Additionally, there are references to quantum physics and the unexpected correlation between frequency and mass in calculations related to electrons. The inquiry seeks a straightforward calculation of the necessary gravitational acceleration for the specified conditions.
shintashi
Hi. I've been having some difficulty with calculating this equation, mainly because I've forgotten most of the equations over the years, and this is sort of a reverse algebra form of an equation I scarcely remember. (i.e., I'm screwed)
Ok, here goes.
Assume you have objects, as per satelites(sp?) around a central field. (wewill call this central field a "planet"
This planet has a radius of aproximately less than 25pm, or to say, 25 picometers. Some prefer this planet have a radius of 24.2 picometers, but who really cares, right ?
The satelites or "moons" passing by this planet have an inertial velocity of
1.8504e10 meters per second. (for the moment, we are just going to have to suspend that whole "C" thing to work out the math)
So the question is, what would the gravitational acceleration, have to be, in order to "catch" these moons in an orbit of 25pm. Obviously we don't want much more or less than this number.
Buddha says " If planet's gravity is too tight, moon collide with planet; but if planet's gravity is too loose, moon will fly away"
one of the things that bugged me about this was that when gravity accelerates, you normally only count the first 50% of distance travelled, but count 100% of the speed from acceleration.
if its easier on you, you can use picometers and picoseconds, I started to, before it got too confusing.
As far as mass- well, a bowling ball and a feather both fall the same in vacuum, so it doesn't matter what the mass of the "moons" are. All I am ask for the aceleration rate in meters, or picometers, or kilometers, or whatever, at 25 picometers radius, each second.
well, assuming it maintains its velocity, you can just say that a=v^2 /r where r is the orbit length plus the planets radius: 50pm, and v is 1.804e10 m/s. i think that makes sense.
ahh, there I am :smile: I wondered where I got moved to. I think this is an ok move, and I will happily punch in the data of pperkins.
I put it in Quantum physics originally, because its an excerpt from that area, although the question itself is pretty basic *whoo*
I was attempting to calculate how much actual force/kinetic energy/etc. was really in an electron, assuming a cymatic oscillation of @1.2e20 hz and a 2.42e-11 m radius. Something caught my eye about an old theory postulated concerning the actual Spin of an electron, and its superluminal paradox. As a side note, some how, when punched in the numbers I came up with for its mass (based upon sqrt Gravitational constant, etc.) was virtually identical to the frequency, which was really weird.
For one, you wouldn't think that you could get within decimal points of the scientific notion of 100 quintillion hertz, and you would probably be equally suprised if the calculator was telling you, that THAT new number, was also the "mass" in what you can only conclude is kilograms.
I thought this was odd, but there must have been something done right, since I did not use the 6.67300 × 10-11 in my original numbers, yet it still produced a value identical... i.e., the equation was saying
"frequency = mass"
But that's besides the point. Just thought I would explain why my brain told me to put this part of the bigger equation in the quantum physics instead of general area.
Thank you thank you pperkins, and anyone else who has a fun and simple way of answering the question. :D
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
