Basic trig question for physics
  • Thread starter Thread starter laminar
    Physics Trig
To calculate the phase constant for a mass and spring system in simple harmonic motion, it is necessary to determine the correct quadrant for the angle. When the arctan of a negative number over another negative number is calculated, the resulting angle is in quadrant II. To adjust this to quadrant III, adding π to the angle is required. The rules for trigonometric functions remain consistent across both precalculus and physics contexts. Therefore, adding π ensures the phase constant is correctly represented.
laminar
I have to calculate the phase constant for a mass and spring system for simple harmonic motion. If I find that phi equals the arctan of some negative over another negative number, do I have to add pi to the answer for it to be in quadrant III?
I know this is more of a precalculus question but I don't know if the rules are different for physics.
yes, you have to add \pi.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
