Basis, Linear Transformation, and Powers of a Matrix
The discussion revolves around proving that the set B = {v, Av, A^2v} forms a basis for a 3-dimensional space given that A is a 3x3 matrix with A^3 as the zero matrix and A^2v is not the zero vector. Participants emphasize the importance of linear independence and spanning in establishing a basis. An example of a 2x2 matrix is provided to illustrate how a non-zero matrix can still yield a zero matrix when raised to a power. The conversation highlights the need to understand the implications of matrix powers and diagonalization, although the latter is deemed less critical for this problem. Ultimately, the participants successfully prove that B is a basis and proceed to explore the linear transformation represented by A.
math222
Let A be an 3x3 matrix so that A^3 = {3x3 zero matrix}. Assume there is a vector
v with [A^2][v] ≠ {zero vector}.
(a) Prove that B = {v; Av; [A^2]v} is a basis.
(b) Let T be the linear transformation represented by A in the stan-
dard basis. What is [T]B?
A basis must span the space and be linearly independent. Usually the way we find power matrices is through diagonalization, but I'm not sure how that will happen here.
I'm having trouble understanding how the power of a matrix can become the zero matrix. I'm trying to come up with an example of a matrix and can't really think of anything. I think I need to be able to understand what the diagonal means in this case, but I'm not sure.
Consider this matrix
$$ A = \begin{bmatrix} 0 & 1 \\ 0 & 0\end{bmatrix}$$
Here A ≠ 0, but A2 = 0. This is an example of a 2 x 2 matrix; it's not too hard to find examples among 3 x 3 matrices.
I don't know that the diagonal is important here. I would start with the definition of a basis, particularly the part about the basis vectors being linearly independent. Since the vectors are in R3, and you have three vectors (v, Av, A2v), there are enough of them to form a basis, as long as they are linearly independent.
Ya I think I get it now. I was able to prove the basis. I'm doing the transformation now. Thanks for your help.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 18 ·
