Basis of degree of freedom for monoatomic and diatomic mixture
The discussion centers on calculating the ratio of specific heats (Cp/Cv) for a mixture of 16 grams of helium (He) and 16 grams of oxygen (O2). The participants clarify that helium is a monatomic gas with a Cp/Cv ratio of 5/3, while oxygen is a diatomic gas with a Cp/Cv ratio of 7/3. The effective lambda factor for the mixture is derived using the formula L = (n1 * Cp1 + n2 * Cp2) / (n1 * Cv1 + n2 * Cv2), leading to an approximate Cp/Cv ratio of 1.62 for the mixture. The discussion emphasizes the need for understanding the principles behind these calculations rather than relying solely on approximations.
  • Understanding of monatomic and diatomic gases
  • Familiarity with specific heat capacities (Cp and Cv)
  • Basic knowledge of the ideal gas law
  • Ability to perform mole calculations
  • Study the derivation of specific heat capacities for different gas types
  • Learn about the ideal gas law and its applications in thermodynamics
  • Explore the concept of degrees of freedom in gas mixtures
  • Investigate the implications of the lambda factor in thermodynamic calculations
Students and professionals in physics, chemistry, and engineering, particularly those focusing on thermodynamics and gas mixtures.
nomorevishnu
hi guys
16 grams of helium gas is mixed with 16 grams of oxygen...
what will be the ratio Cp/Cv of the mixture...
how to calculate it?? i thought on the basis of degree of freedom for monoatomic and diatomic mixture...but that can take me to the answer only by approximation...how do we arrive in a a formula that could get me answer...
Aren't they both diatomic?
AM
how?
y do u say that these two are diatomic?
He...its completely satisfied without bonding
He is a noble gas...so y do u say it is diatomic...
moreover someone help me solve the problem yaar...
Monatomic Gases:
Helium, Neon, Argon, Krypton, Xenon, Radon
Single atom, or monatomic, gases have the smallest Specific Heat CV.
Diatomic Gases:
Oxygen, Nitrogen, Hydrogen
Of course you are right. I was seeing He and thinking H.
What is the ratio of the number of He atoms to O2 molecules?
AM
hi
y isn't anyone helping me get the answer?
please if someone can explain the problem to me...it would do a world of good to me...
please please please...the question again...
nomorevishnu Let helium be the gas 1 and oxygen be the gas 2 .
No. Of moles of Helium: 4 = n1
" " " " oxygen: 0.5 =n2
Lamda factor for a mixture is given by:
L= n1( Cp1) + n2 (Cp2) / n1(Cv1) + n2 (Cv2)
Where Cp1/Cv1=5/3 ( for monoatomic helium)
Cp2/Cv2=7/3 for diatomic oxygen
Answer you get is: 1.62
nomorevishnu said:
hi
Have you worked out the proportion of numbers of atoms of He to number of molecules of O2?
AM
well...i knew that equation...and the answer
but to find the effective lambda...how do we get to such an equation...any proof...its not given in Resnick and Halliday
You have to go to basic principles:
dU = (Cp - Cv)nT = nRT so:
C_p/C_v = \gamma = (C_v + R)/C_v = (1 + R/C_v)
So for the mixed gas:
(C_{peff} - C_{veff})n_{total}dT = n_{total}RdT
C_{peff} = (R + C_{veff})
(1)C_{peff}/C_{veff} = \gamma_{eff} = (R/C_{veff} + 1)
Now:
Vdp = (C_{vHe}n_{He} + C_{vO_2}n_{O_2})dT = C_{veff}n_{total}dT
(2) C_{veff} = (C_{vHe}n_{He} + C_{vO_2}n_{O_2})/n_{total}
Substitute from (2) into (1).
I get 1.64
AM
12K
18K
43K
