Basketball Question: Initial Velocity for 2.00 m Player 10.0 m from Basket
  • Thread starter dizco29
  • Tags
    Basketball
In summary: However, this is not the case. x and y must be separated by a t in order for the velocity to be correct.
dizco29
32
4.54) A basketball player who is 2.00 m tall is standing on the floor 10.0 m from the basket, as in Figure P4.54. If he shoots the ball at a 40.0 degree angle with the horizontal, at what initial speed must he throw so that it goes through the hoop without striking the the backboard? The basket height is 3.05 m.
Again I drew a diagram. I could subtract 3.05 from 2.00 to give me 1.05m. So now I figure I can use equations
vxi = (vi)(cos)(angle)
and
vyi = (vi)(sin)(angle)
I have as a result:
10 = (vxi)(t)
and
1.05 = (vyi)(t) - 4.9 t^2
As you can see, I'm missing a few things. but I go through the motions of multiply through what i can.
for x: 10 = (vi)(cos)(40)
for y: 1.05 = (vi)(sin)(40)t - 4.9t^2
10 =(vi)(0.76604)
10/0.76604 = 13.05 (Initional velocity)
I than use the intital velocity and plug it into the y component equation. 1.05 = (13.05)(sin)(40)t - 4.9t^2
1.05 = (8.38834)t - 4.9t^2
-4.9t^2+8.38t-1.05
now that we have a quadratic equation, I put it through a quadratic formula to give me 1.5 seconds.
so the equation I use for intitial velocity is x = v(t).
10 = vxi (1.5) = 6.66 m/s
and
1.05 = vyi (1.5) - 4.9 (1.5)^2 = 8.05 m/s
so once I have those two velocities, I use a^2+b^2=c^2 to find the hypoteuse which yields 10.4478 m/s for my initial velocity.
Just to let you know, I am very new to physics, in fact this is teh first college physics course I am taking, so for all I know, all my answers could be wrong. If you guys can let em know the right way about going through problems, and tips or tricks, it would be much appreciated.
If you guys can double check my answers and let me know, I would really appreciate that as well :)
take care and thanks very much!
Neeraj
dizco29 said:
10 = (vxi)(t)
and
for x: 10 = (vi)(cos)(40)(t)
What happened to the (t) I added to your quote? Looks to me like you lost it.
ooops, right you are, it was a typo. But does the answer look right? Is the rest of my approach right?
If you dropped the (t), then your 13.05 number is not right, and since you used it, what follows cannot be right. Go through it yourself with the correction and see where it leads. A lot of what you did seems to be on the right track, but that (t) will change things.
oh I see! I was close though! lol. I will make the necessary corrections and post them soon. Can't express how much I appreciate your help Dan!
Thanks a million!
Neeraj
and
I have as a result:
10 = (vxi)(t)
and
for vxi: 10 = (vi)(cos)(40)
10 =(vi)(0.76604)
I than use the intital velocity and plug it into the y component equation. 1.05 = (13.05)(sin)(40)t - 4.9t^2 (MY STUPID MISTAKE!)
-4.9t^2+8.38t-1.05
and
Neeraj
made a mistake with the x-component
Ooops, I think I made a grave error after I founf my vxi = 13.05 m/s.
I assumed I could take that velocity and plug it into my equation for the y-component, which I now realize is totally wrong. Both x and y components should be solved seperately. I mistook 13.05 to be vi instead of vxi. Know this, how can I find the initial velocity for my y-component?
any ideas?
k, I think I may have figured out my error. Let me know if this sounds good. :)
and
I have as a result:
10 = (vxi)(t)
and
10 =(vi)(0.76604)
I than use the intital velocity and plug it into x=(vi)(cos)(angle)(t)
10 = 13.05cos 40 \t
10=(9.9996)t
t = 1.000 sec
so now that I have my time, I plug that into my y-component equation:
1.05 = vi sin 40 (1.000) - 4.9 (1.000)^2
which gives me 9.2566 m/s
Now that I have my vxi and vyi. I can plag those into pithegora's theorum to find my hypoteneuse.
(13.05)^2 = (9.2566)^2 = 255.987 ( I take the square root and get...)
15.9995 m/s for my initial velocity
(does that sound right) ?
any ideas?
Go back to the beginning and write your equations for the x and y positions versus time. You can solve the x equation for (t) and substitute the exprssion for (t) into the y equation. You will then have a relationship between the two initial velocity components. If you had a second relationship between these components, you could solve for them. The problem gives you the information you need to get this second relationship. What is it?
would it be this?
10 = 13.05cos 40 \t
10=(9.9996)t
t = 1.000 sec
The second relationship you speak of is the Initial velocity when you solve for the hypotenuese, right?)
dizco29 said:
would it be this?
No. You can't find the initial x velocity from just the one equation. Do what I said in my previous post.
ooop! I see my error. Just realized I can't have 13.05 as an inital x velocity.
So going back to the begining, I have the two x and y equations:
10 = vxi (cos) (40) t
and
1.05 = vyi (t) - 4.9t^2
the way I see it, I can find time from the y equation, if I assume that vyi is 0 as that's the apex of the hight if the ball. so I'm left with...
1.05= 0- 4.9t^2
1.04/4.9 = t^2
t = 0.4629 x 2
t = 0.9258
can I plug that into my x equation to find vxi? Or did I make another mistake? (I know you told me I can get time from the x equation, but it looks like I have 2 unknowns there. I have to hand it to you, you're being very patient with me, I really appreciate it Dan! Thanks!)
oh wait. that's wrong, I can't have vyi = 0. That wouldn't make sense. sorry.
Good for you. You are going to have to find those two relationships between the velocity components I mentioned earlier. There is no avoiding it.
Related to Basketball Question: Initial Velocity for 2.00 m Player 10.0 m from Basket
1. What is initial velocity in basketball?
Initial velocity in basketball refers to the speed at which a player's movement begins when they first start moving towards the basket. It is the starting point for calculating a player's trajectory towards the basket.
2. How is initial velocity calculated in basketball?
To calculate initial velocity in basketball, you need to know the distance between the player and the basket, as well as the time it takes the player to reach the basket. You can then use the formula v = d/t, where v is the initial velocity, d is the distance, and t is the time.
3. Why is initial velocity important in basketball?
Initial velocity is important in basketball because it determines the trajectory of a player's shot towards the basket. It also affects the amount of force and speed a player needs to put into their shot to make it into the basket.
4. How does a player's initial velocity affect their shot in basketball?
A player's initial velocity is a crucial factor in determining the success of their shot in basketball. If a player has a higher initial velocity, their shot will have more force and speed, making it more likely to reach the basket. On the other hand, a lower initial velocity can result in a weaker shot that may not make it to the basket.
5. How can a player improve their initial velocity in basketball?
To improve their initial velocity in basketball, a player can work on their strength and speed through exercises such as weightlifting, sprinting, and plyometrics. They can also focus on proper shooting technique, including using their legs and upper body to generate power for their shot.
9K
