Batteries in parallel with a diode
Connecting a 17V DC source in parallel with a 9V battery that has a diode will prevent current flow into the battery due to the diode's reverse bias. The voltage drop across the diode and the 9V battery will equal the 17V DC source, resulting in no current flow in the circuit. To protect the battery from discharging back into the 17V supply, a diode in series with the 17V source is recommended. This setup ensures that the battery only provides power if the 17V source fails. Overall, the configuration effectively isolates the battery from the higher voltage source.
quantumlight
I was wondering what the effects are if any if I connect a 17V DC source in parallel with a 9 V battery but the 9 V battery has a diode that prevents current from flowing into it. Thanks
That's OK. Did you want the 9V battery there to give a supply if the 17V fails?
You may also want a diode in series with the 17V supply to prevent the battery discharging back into it when it fails (in case there is a path to Earth inside the 17V supply).
no current will flow through the circuit as the voltage drop across the reverse biased diode and the 9V battery will be equal to 17V DC source
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
  • · Replies 42 ·
  • · Replies 29 ·
