Bead on wire tilted at angle theta.
7 replies · 5K views
AbigailM
Consider a bead of mass m constrained to slide without friction along a rigid wire that rotates about the vertical at a fixed angle [itex]\theta[/itex] with constant angular velocity [itex]\omega[/itex]. Write down the Lagrangian in terms of z as the general coordinate. Find the equation of motion of the bead, and determine whether there are positions of equilibrium. If there are equilibrium positions, are they stable?
[itex]z=rcos\theta[/itex]
[itex]U=mgz[/itex]
[itex]\dot{r}=\frac{\dot{z}}{cos\theta}[/itex]
[itex]T=\frac{1}{2}m(\dot{r}^{2}+r^{2}\dot{\theta}^{2})[/itex]
[itex]L=\frac{2}{3}m(\frac{\dot{z}^{2}}{cos^{2}\theta}+(z\omega)^{2}/(cos^{2}\theta}))-mgz[/itex]
[itex]m\ddot{z}=2z\omega^{2}-mgcos^{2}\theta[/itex]
[itex]\ddot{z}=\frac{2z\omega^{2}}{m}-gcos^{2}\theta[/itex]
Just wondering if my equation of motion is correct. Thanks for the help
Note that [itex]\theta[/itex] is a fixed angle. So, [itex]\dot{θ}[/itex] = 0.
You will need a kinetic energy term that takes into account the azimuthal motion ("swinging around motion") around the axis of rotation at the angular speed ω. So, see if you can construct a kinetic energy term involving ω, z, and [itex]\theta[/itex]. Of course, you will still have the kinetic energy term [itex]\frac{1}{2}[/itex]m[itex]\dot{r}[/itex]2.
TSny,
Using your advice I get:
[itex]L=\frac{1}{2}m(\frac{\dot{z}^{2}}{cos^{2}\theta}+(z^{2}\omega^{2})/(cos^{2}\theta))-mgz[/itex]
Does this look ok?
Thanks.
The kinetic energy associated with the rotation about the z axis would be (1/2)m(ωd)2 where d is the radius of the circular motion about the z-axis. If the bead is a distance r out along the wire, then check that d = r sinθ. d can then be expressed in terms of z by using r = z/cosθ.
So, verify that the second term of the Lagrangian would have a tan2θ in place of the 1/cos2θ.
You should find that the mass m cancels out in the equation of motion for [itex]\ddot{z}[/itex]. Also, you have a factor of 2 in the first term on the right hand side of the equation for [itex]\ddot{z}[/itex] that should not be there.
Awesome that made it perfectly clear and I got the correct answer. Thanks so much for the help!
Also to find any equilibrium positions I looked at what would make [itex]\ddot{z}=0[/itex].
I got only 1 equilibrium position of [itex]z=\frac{g}{tan^{2}\theta\omega^{2}}[/itex].
I also concluded that this is stable since [itex]\omega[/itex] and [itex]\theta[/itex] are constant.
Your equilibrium value for z looks correct to me.
However, I believe it's an unstable equilibrium. One way to see this is to go back to your result for [itex]\ddot{z}[/itex].
[itex]\ddot{z}[/itex] = sin2θ ω2 z - g cos2θ
Imagine placing the bead on the rod at the equilibrium position where [itex]\ddot{z}[/itex] = 0. Then displace the bead a little bit farther out on the rod. This will make z greater than the equilibrium value of z and an inspection of the expression for [itex]\ddot{z}[/itex] shows that [itex]\ddot{z}[/itex] will become positive. So, if you let the bead go from this position, which way would it begin to move?
Similarly, analyze what would happen if you displaced the bead a small amount in the opposite direction from the equilibrium position.
