[beginner] Network coverage inside an elevator?
Telecom operators assert that users can maintain network coverage inside elevators, despite elevators being metal structures that act as closed conductors. Gauss' theorem suggests no charge exists inside a closed conductor, raising questions about signal reception. However, cell phones operate on electrodynamics, utilizing electromagnetic waves rather than electrostatics. While elevators may attenuate signals, they do not completely block them, allowing for some frequencies to pass through effectively. Therefore, network coverage can still be achieved inside elevators under certain conditions.
rahuld.exe
So many telecom operators claim that their users will get network coverage even inside an elevator. But according to Gauss' theorem, no charge is supposed to exist inside a closed conductor and an elevator (made of metal) is a closed conductor... So how is one supposed to get network coverage inside?
You're thinking in terms of electrostatics. Cell phones work using electrodynamics to transmit signals, i.e. photons/electromagnetic waves.
The elevator will attenuate some of the signal but at the right frequencies the signal will mostly pass through the elevator boundary.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 23 ·
  • · Replies 26 ·
15K
