Behavior of MR Fluids in Magnetic Fields
The discussion focuses on the behavior of magnetorheological (MR) fluids when rotated inside a hollow shaft under magnetic fields. Participants emphasize the need for specific details regarding the magnetic fields and flow patterns to provide accurate insights. Clarifications are made regarding the terminology, correcting "magnetoreactive" to "magnetorheological." The conversation highlights the complexity of MR fluid behavior in such conditions. Further contributions from knowledgeable members are encouraged for a more comprehensive understanding.
LP Manikandan
Like to know the behavior of MR Fluids when rotated inside a hollow shaft subjected to magnetic fields.. Could anyone please help
Welcome to PF, LP.
I'm going to assume that MR means magnetoreactive. If that is incorrect, ignore the next sentence.
The exact nature of the magnetic fields would have to be specified, as would the nature of the flow pattern within the tube.
That's all that I've got. You'll have to wait for others to respond in order to obtain a decent answer.
Actually it is not MAGNETOREACTIVE but it is MAGNETORHEOLOGICAL.. Sorry for the insufficient message..
That's okay. I'll just slink on back home now...
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
