Belt C-C distance to Tension
The discussion revolves around the relationship between initial belt tension and pulley center-to-center (C-C) distance for timing belts, exploring theoretical models and practical implications. Participants examine whether an equation exists that links these two parameters and consider the complexities involved in deriving such a relationship.
  • Some participants inquire about a known equation relating tension to C-C distance, suggesting that initial tension is typically based on the applied load.
  • One participant proposes that, theoretically, the zero length of the belt path can be computed from C-C distance, initial belt length, and Hook's law, allowing for tension computation based on extension.
  • Others note that in practice, tension varies across different parts of the belt and is influenced by dynamic harmonics, complicating the relationship.
  • A participant mentions the use of a mechanical tensioner in real applications to maintain specified tension, independent of variations in belt path length, wear, or aging.
  • Another participant discusses calculating Young's modulus of the belt using a composite materials approach, indicating a specific method for determining material properties relevant to tension calculations.
  • Concerns are raised about the assumption that a direct relationship exists between C-C distance and tension, with some suggesting that C-C distance is determined by engine architecture rather than belt tension.
  • One participant describes the characteristics of the GT3 belt profile and how increased tension may affect the contact area between the belt and pulley, particularly on small diameter pulleys.
Participants express differing views on whether a direct relationship exists between initial belt tension and C-C distance, with some arguing that the relationship is complex and influenced by various factors. The discussion remains unresolved regarding the existence of a definitive equation linking the two parameters.
Limitations include the complexity of the tension distribution along the belt, the influence of dynamic harmonics, and the dependence on specific material properties and geometries. The discussion also highlights the potential for variations in tension due to mechanical factors and the internal architecture of the engine.
RodrigoBlakenship
TL;DR
Is there a known equation relating tension to C-C distance?
Hi all,
I've looked through design manuals (SDP/SI, Gates, Naismith) and textbooks like Shigley's, but haven't found an equation linking initial belt tension to pulley center-to-center distance for a timing belt. I understand initial tension is typically based on the applied load, but I'm curious:
A) Is there a known equation relating tension to C-C distance?
B) If not, how might one go about deriving it?
Thanks in advance!
In theory, given the C-C distance, the zero length of the belt path can be computed. Knowing the initial belt length, Hook's law, and also the spring constant, allows tension to be computed, in proportion to extension.
In practice, the tension will be different in different parts of the belt, and there will be dynamic harmonics present. The belt will be a V-belt, and the sectional width of the V will be reduced by tension, so that it will drop and wedge deeper into the V of the pulley, increasing grip, while changing the computed zero tension length. That will rapidly become too complex to compute.
In real applications, a mechanical tensioner is employed with belts to maintain a specified tension in the belt, independent of variations in belt path length, wear, or aging of the belt.
TL;DR: Is there a known equation relating tension to C-C distance?
Thanks in advance!
Welcome!
What makes you believe that a relation exists between those two parameters?
The C-C distance is determined by the internal architecture of the engine (locations of crank and cam shafts).
Dear Baluncore,
I am trying your approach involving Hooke's law and I was wondering if I could please have some feedback on my method? The belt is composed of several fibreglass cords running along the length of the belt covered by neoprene. I am calculating the Young's modulus of the belt using EC = EF VF + EM VM , where VF and VM are the volume fractions of fibers and matrix (neoprene) respectively and EC is the Young's modulus of the belt.
I took this method from a free textbook on composites (https://www.princeton.edu/~maelabs/hpt/materials/composites.htm). Images of the internal structure of the belt can be found here: https://www.gates.com/in/en/power-t...r-synchronous-belts.p.9356-000000-000000.html
Thank you for explaining about the change in belt tension due to the wedging of the V of the pulley and the effect of harmonics. I will adapt that knowledge to timing belts and write that as a disclaimer/limitation of my theoretical model.
Lnewqban said:
Welcome!
Dear Lnewqban,
This is just a general model that applies to two generic timing pulleys (GT3 profile). I just wanted a theoretical model linking belt tension to C-C distance. In this use case there is no tensioner and pre-tension is only provided by the C-C distance. Although the belt will lose this initial tension, this is not important for this use case.
The GT3 is a stepped belt so it should run flat on the pulley, indexed by the rounded teeth. As you increase belt tension, the rubber between the pulley surface and the fibre layer may be crushed slightly. That will be most significant on small diameter pulleys, where the area of face contact between the belt and pulley is small, so the pressure is higher.
It is likely that the pulley mounting structure will deflect more than the changes in the length of the fibre reinforced belt.
  • · Replies 45 ·
26K
  • · Replies 20 ·
21K
14K
  • · Replies 17 ·
