Bernoulli Principle: Homework Solution
1 reply · 6K views
srollin6
Water Flows upward throw the pipe shown in the diagram at 96 L/Min. If the pressure at the lower end is 80kPa, find the velocity of the water is at both ends and the pressure at the upper end. Assume that the density of water remains constant throughout the tube and that h1= 10 m and h2 = 13m
P1+ 1/2 ρv^2+gy1=P2+1/2ρv2^2+gy2
Continuity Equ:
A1V1=A2V2
(Tried to use this equation to hep me find the velocity but given their is no diameter or radius given to find the are it was a waste of time)
volume flow rate up the pipe:
96L/min (1.0X10^3 cm^3/ 1.00L)(1.00m/100cm)^3(1.00min/60sec) = 1.6x10^3 m^3/s
Attempt to tried to use the Continuity Equation as substitution for one of the velocities:
A1V1=A2V2
V2(A2/A1)= V1
Substituting V1 in the Bernoulli Equation:
P1+1/2ρ(V2(A2/A1))^2+ρgy1=P2+1/2ρv2^2+gy2
2g(y^2-y1)=v2[1-(A2/A1)]
sqrt(2gh)/sqrt(1-(A2/A1)^2) =v2
Any help or guidance will be appreciated. Thank you.
srollin6 said:
... find the velocity of the water is at both ends ...
Something missing in the problem statement?
P1+ 1/2 ρv12+gy1=P2+1/2ρv22+gy2
Should be ρgy1, ρgy2, yes?
Continuity Equ:
A1V1=A2V2
It doesn't mention any change in area, so presumably A1=A2.
P1+1/2ρ(V2(A2/A1))2+ρgy1=P2+1/2ρv22+gy2
How do you get that last equation from the preceding one? What happened to P1 and P2?
