Bernoulli's Equation Pressure at Blockage
2 replies · 2K views
quark002
Bernoulli's equation tells us that a portion of a stream that is slower-moving has a higher pressure than a portion of the same stream that is faster-moving. What would happen if I blocked the flow of two different streams, a faster-moving stream and a slower-moving stream? Why would I experience a higher pressure when blocking the faster-moving stream?
$$\frac{p}{\rho} + \frac{v^2}{2} = \text{cst}$$
Would it be because I'm comparing two different streams as opposed to two portions of the same stream?
If there are two different streams there is no relationship between their pressures. You could add a constant pressure throughout one of the streams and nothing would change in the flow.
