Bernoulli's equation to find the flow rate
Sall1230
" A horizontal water pipe has a radius of 10 cm and a pressure of 8*10^4 Pa at one end. At the other end the radius is 5 cm and the pressure is 6*10^4 Pa. What is the water flow rate through this pipe?
P1 + 0.5 * ρ * v1^2 + h1ρg = P2 + 0.5 * ρ * v2^2 + h2ρg[/B]
A1 v1 = A2 v2
I tried to calculate each velocity individually,
V1= 2P/ρ = 2(8*10^4)/1000= 12.65
V2= 2(6*10^4)/1000 = 10.95
Which means that this is not true since v2 must be bigger considering the pressure dropped. So I tried this law:
P1-P2= 0.5 ρ ( v2^2 -v1^2)
The answer : (v2^2-v1^2) = 40
So I tried to plug it in with the equation Q= Av
(15*10^-2)^2 * 3.14 * 40
But it still didn't seem right
P1 + 0.5 * ρ * v12 + h1ρg = P2 + 0.5 * ρ * v22 + h2ρg[/B]
A1 v1 = A2 v2
V1= 2P/ρ = 2(8*104)/1000= 12.65
V2= 2(6*104)/1000 = 10.95
You can't do this because there isn't enough information.
P1-P2= 0.5 ρ ( v22 -v12)
This is the result of actually applying the Bernoulli equation to this pipe.
The answer : (v22-v12) = 40
This is also correct.
This is where you went off the rails.
You use the continuity equation, A1 v1 = A2 v2, to find a relationship between v1 and v2. Once that relationship is established, then you can solve
(v22-v12) = 40
for v1 or v2, depending on your choice. Once the flow velocity is found, then the flow rate can be calculated.
(v22-v12) = 40
Ok so:
v2^2 - v1^2 = 40
A1 v1 = A2 v2
(10*10^-2)^2 v1 = ( 5*10^-2)^2 v2
0.01 v1 = 0.025 v2
v2 = 4 v1
Putting it in the equation v2^2 - v1^2 = 40
(4v1)^2 - v1^2 = 40
16v1^2 - v1^2 = 40
15v1^2 = 40
v1^2 = 40/15
v1= 1.632 m/s
Q= Av
Q= (10*10^-2)^2 * 3.14 * 1.632
Q= 0.0512 kg/m^3
Is my way correct?
Sall1230 said:
Ok so:
v2^2 - v1^2 = 40
A1 v1 = A2 v2
0.01 v1 = 0.025 v2
v2 = 4 v1
(4v1)^2 - v1^2 = 40
16v1^2 - v1^2 = 40
15v1^2 = 40
v1^2 = 40/15
v1= 1.632 m/s
Q= Av
Q= 0.0512 kg/m^3
Is my way correct?
Yes, except 0.0512 kg/m3 is not a flow rate, at least it doesn't have the correct units.
Remember, v1 has units of m/s.
