Is Density Affected By Fluid Speed According To Bernoulli's Principle?
The discussion centers on the relationship between fluid speed, density, and pressure as described by Bernoulli's Principle. It highlights the confusion that arises when considering that an increase in fluid speed should lead to an increase in density due to tighter packing in narrower areas. However, Bernoulli's Principle indicates that as fluid speed increases, pressure decreases, which suggests that density should also decrease in compressible flows. The conversation clarifies that for incompressible flow, density remains constant, while for compressible flow, density varies inversely with pressure. Understanding these principles helps resolve the initial confusion regarding the effects of fluid speed on density.
BrooklynBees
I have in my notes that as speed of a fluid increases, density decreases.
This doesn't make sense to me. When a fluid passes through a narrower area, doesn't that mean that its density is increasing because it is now packed more tightly together? If this is the case, shouldn't the rule be that as speed increases, density increases (in accordance with the concept that a fluid passing through a narrower area speeds up to maintain flow rate)?
I also have in my notes that as pressure increases, density increases.
As I stated in the previous paragraph, it seems to me that as speed increases, density should also increase. However, Bernoulli's Principle states that as a fluid's speed increases, pressure decreases. So shouldn't the rule be that as pressure increases, density decreases? (If someone helps me understand the rule from the first paragraph, I'll likely be able to figure this rule out on my own).
Thank you
Bernoulli's principle is so interesting because of this counter-intuitiveness!
The way I like to think of it is that energy density in a fluid is constant. In a formula:
pressure + .5*density*velocity^2 + mass*g*density*vertical displacement = constant
It should be clear from this that increasing velocity decreases pressure or decreases density (usually pressure).
"increasing velocity increases pressure"
I thought the whole idea of Bernoulli's principle was that increasing velocity decreases pressure...?
I mistyped, I've edited it.
Thank you
For incompressible flow the density will be constant. This is the typical assumption (one of them any way) with the Bernoulli Principle.
For compressible flow, the density will vary depending on the pressure. As the pressure increases the density increases and vice versa.
CS
Hmm. Okay.
Another question, then.
Is the following statement true?:
the narrower the pipe, the higher the density
Nvm, reading the previous post.
OHHH! I get it.
  • · Replies 43 ·
