Best Method of Focusing Solar Power
The discussion focuses on building a solar-powered distillation machine using a fiberglass satellite dish. Two methods for creating a reflective surface are proposed: molding an acrylic plexiglass mirror or gluing small mirrors onto the dish. The consensus suggests that using a few larger mirrors or aluminized mylar may be more effective than attempting to mold a single piece, as maintaining specular reflection is crucial for efficient heating. Additionally, resources such as "solar concentrators" and design mistake avoidance guides are recommended for further learning.
  • Understanding of solar energy principles
  • Basic knowledge of optics and reflection
  • Familiarity with materials like acrylic plexiglass and aluminized mylar
  • Experience with DIY projects and construction techniques
  • Research "solar concentrators" for design insights and techniques
  • Explore the properties and applications of "aluminized mylar" in solar projects
  • Investigate the effectiveness of "specular vs. diffuse reflection" in solar heating
  • Study common "design mistakes in solar concentrators" to enhance project success
This discussion is beneficial for DIY enthusiasts, high school students interested in science projects, and anyone exploring solar energy applications for distillation or heating purposes.
Thundagere
If I keep this up, I'm going to get a rep around here :).
So, I recently acquired a fiberglass satellite dish which I plan to use for building a cheap, solar powered distillation machine. The idea is to have the dish, calculate the focal point, and run a double glass plated chamber at the focal point. THis allows light in, let's it get heated, then retains the heat long enough for it to boil. Keep in mind, as a high school freshman, this is partially for fun, but I might enter it in a science fair. I want this to be as resourceful and documented as possible.
So, here's the real question. I'm thinking of either a) Taking an acrilyc plexiglass mirror and placing it on the fiberglass dish, then putting it in an oven and molding it into the parabolic shape, or
b) Gluing on hundreds of small mirrors.
I want to know, would the first idea work or would the mirror get too warped and make light go through diffiuse reflection, or would it still be specular? Which method would be best for my project of boiling water?
With the amount of water I have, I need about 298000 J. The sun gives off about 1000 W/m^2, I believe (a bit more, but I'm averagin and including nightfall). That's just background info, but what do you guys think?
Any ideas on this? I don't mean to go crazy asking but I'm honestly not sure if I can keep specular reflection when the acrilyc melts.
It will be tough to mold it properly in my opinion. Glueing hundreds of tiny mirrors is something that I've seen be done before, but I can understand why that wouldn't be your favourite approach.
A few shaving mirrors I would have thought would do the trick
I'd say get about 10-20 small mirrors and place on the dish. They don't need to be curved, and it might be easier than making one big curved mirror or using hundreds of small ones. It really depends on how much time you want to spend on this.
If the parabolic dish is smooth enough you may use aluminized mylar. It's thin, light weight, cheap, and highly reflective.
As I mentioned before, and Drakkith re-mentions: your focusing doesn't have to be excessively accurate or excessively granular. If your heating vessel is, say, 4 inches in diameter then your mirrored tiles do not need to need much smaller than 4 inches. As long as the "beam" from each mirror is smaller in diameter than the heating vessel, you're good to go.
You'd only need a smooth surface if you wanted a point focus.
  • · Replies 16 ·
  • · Replies 32 ·
  • · Replies 30 ·
