Best way to hold an object for measurement using multimeter?
To accurately measure small components with a multimeter, using non-conductive clips or tweezers designed for small parts is recommended to avoid interference from hand placement. Repeated measurements can help ensure consistency and accuracy. If the multimeter readings differ significantly from expected values, it may indicate issues with component tolerance or measurement technique. Soldering or using short wires with crocodile clips can also facilitate better connections. Proper handling techniques are essential for reliable measurements in electronics.
Deathfish
What is the best way to hold it against multimeter sharp probes? The component is quite small and i want to avoid inaccurate result due to my hands holding it / placing it on the bench top
With non-conductive clips, or very carefully. Or try it a few times to see if you get similar results. Or have someone else try to reproduce your measurement.
...I honestly don't see why you couldn't have thought of any of those ideas yourself.
i can't buy the stuff cos I'm just supposed to use the stuff school provides...
anw I'm asking this cos the color code might say 10K ohms or 1K ohms but the multimeter registers just about 9.1K or 890 ohms ... the tolerance shouldn't be that wide, I'm bad at recognizing colors so that compounds the problem
using bread board to assemble the circuit
Sometimes you can solder (?) or just twist short lengths of wire to the component and use crocodile clips to attach to the ends.
And - yes - it can be a real pain!
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 16 ·
  • · Replies 54 ·
9K
  • · Replies 21 ·
