Binomial Distribution Probability
azdang
Let X be a Binomial B(\frac{1}{2},n), where n=2m.
Let a(m,k) = \frac{4^m}{(\stackrel{2m}{m})}P(X = m + k).
Show that lim_{m->\infty}(a(m,k))^2 = e^{-k^2}.
So far, I've found that P(X = m+k) = (\stackrel{2m}{m+k}) \frac{1}{4^m}
Then, a(m,k)=\frac{m!m!}{(m+k)!(m-k)!}.
But I have no idea how to show that the limit of a^2 will be equal to e^{-k^2}.
I think my work up to that point seems okay. I got things to cancel out, so that is usually a good sign. Any hints? Thank you!
I got what you got, and this is not a good sign. If we are correct, then look at the k=3 case.
a(m,3) simplifies to \frac{m(m-1)(m-2)}{(m+3)(m+2)(m+1)} and the limit is 1 as m approaches infinity.
Well, we are looking for the limit of a^2. Does that make a difference?
Also, you said you got the same thing as me, but I'm a little confused how what you wrote (even though I know it's for the specific k=3 case) is the same as what I got. I'll look at it again to see if I can see the connection, but maybe what I got for a was wrong?
a(m,3)=\frac{m!m!}{(m+3)!(m-3)!}=\frac{m!\cdot m(m-1)(m-2)(m-3)!}{(m+3)(m+2)(m+1)m!\cdot (m-3)!}<br /> =\frac{m(m-1)(m-2)}{(m+3)(m+2)(m+1)}
and
\lim_{m\to\infty}a(m,3)^2=\left(\lim_{m\to\infty}a(m,3)\right)^2=1^2=1
I think you should check if the problem is stated correctly. I get the same thing as you did for a(m,k) every time I check.
Yep, that's definitely what the problem says so, I'm not sure.
What you've shown definitely seems right and I'm assuming it works for other cases when k is something else, as well. I'll check it out and ask my teacher about it if need be. Thanks!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
