Comp Sci Bisection Method for Finding Roots of x^3+4x^2-x-1 in C++
The discussion focuses on implementing the Bisection Method in C++ to find roots of the equation x^3 + 4x^2 - x - 1. A key issue raised is the incorrect condition in the loop that prevents it from functioning as intended; specifically, the loop does not iterate properly because the condition checks if the absolute value of c1 is less than 0.01, which is not aligned with the goal of stopping when it is less than 0.001. Participants suggest correcting the loop's logic to ensure it continues until the desired precision is achieved. The code includes functions to evaluate the polynomial at different points and uses a do-while loop for the bisection process. Proper adjustments to the loop condition will enable the program to accurately find the root.
Sumaya
find the roots ( interval halving ) , I want to know how to make a condition statement that when fun3 be less than 0.001 and then loop will stop and i get the root .(here in my code i don't know why the loop doesn't work as it should ..
the equation is : x^3+4x^2-x-1
Code:
// UniqueName.cpp : Bisection Method in c++
#include "stdafx.h"
#include<iostream>
#include <math.h>
using namespace std;
float fun1(float);
float fun2(float);
float fun3(float);
void main()
float a,b,c,a1,b1,c1;
int i=0;
cin>>a>>b;
a1=fun1(a);
b1=fun2(b);
c=(a+b)/2;
c1=fun3(c);
           if((a1*b1)<0)
			  do{
              if ((a1*c1)<0)
				  b=c;
			  else if((c1*b1)<0)
				  a=c;
			  else
				  break;
			  while(fabs (c1)<0.01);
		 cout<<"The root  is    "<<c<<endl;
float fun1( float a)
	float y;
	y=a*a*a+4*a*a-a-1;
	return y;
float fun2( float b)
	float y;
	y=b*b*b+4*b*b-b-1;
	return y;
float fun3( float c)
	float y;
	y=c*c*c+4*c*c-c-1;
	return y;
thanx in advance
Code:
#include "stdafx.h"
#include<iostream>
#include <math.h>
float fun1(float);
float fun2(float);
float fun3(float);
void main()
int i=0;
cin>>a>>b;
a1=fun1(a);
b1=fun2(b);
c=(a+b)/2;
c1=fun3(c);
if((a1*b1)<0)
   do{
       if ((a1*c1)<0)
         b=c;
      else if((c1*b1)<0)
         a=c;
      else
         break;
	float y;
	y=a*a*a+4*a*a-a-1;
	return y;
	float y;
	y=b*b*b+4*b*b-b-1;
	return y;
	float y;
	y=c*c*c+4*c*c-c-1;
	return y;
Just as in the other thread you started, the logic in your do while loop is backwards. The first time through fabs(c1) > .01, so the loop doesn't do more than one iteration.
thank u all <3
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
