Bivariate Transformation of Random Variables
Yagoda
Two RVs X1 and X2 are continuous and have joint pdf [itex] f_{X_1,X_2}(x_1, x_2) = \begin{cases} x_1+x_2 &\mbox{for } 0 < x_1 < 1; 0 < x_2 < 1<br /> \\<br /> 0 & \mbox{ } \text{otherwise}. \end{cases}[/itex]
Find the pdf of [itex]Y = X_1X_2[/itex].
I'm using the transformation "shortcut' that says if U = g1(x,y), V = g2(x,y) and h1(u,v) = x, h2(u,v) = y then
[itex]f_{U,V}(u,v) = f_{X,Y}(h_1(u,v), h_2(u,v) \times |J|[/itex] where |J| is the absolute value of the determinant of the Jacobian of h1 and h2.
In this setting I let [itex]Y = X_1X_2[/itex] and [itex]Z = X_1[/itex] so [itex]h_1(y,z) = Z[/itex] and [itex]h_2(y,z) = Y/Z[/itex]. Then I calculated [itex]|J| = \frac{1}{Z}[/itex] so plugging in I got that
[itex]f_{Y,Z}(y,z) = (z + \frac{y}{z})(\frac{1}{z}) = 1 + \frac{y}{z^2}[/itex] where [itex]0 < z < 1, 0 < y < z[/itex].
So to find the pdf of Y, integrate with respect to z over all possible values of z, but this integral does not converge when evaluated from 0 to 1.
I've tried other choices for Z, but I've ended up with the same problem.
Note: if both [itex]0 \le x_1 \le 1[/itex] and [itex]0 \le x_2 \le 1[/itex], how does the product
[itex]X_1 X_2[/itex] compare in size to [itex]X_1[/itex] alone?
Edited to add: I have not stepped through all of your work to simplify the transformation, simply noted that you have [itex]0 < z < 1[/itex] and [itex]0 < y < 1[/itex].
Since [itex]X_1[/itex] and [itex]X_2[/itex] are both smaller than 1, then their product will be smaller than [itex]X_1[/itex] alone, but I'm not seeing how this helps me find the pdf of [itex]Y[/itex].
Are the limits [itex]0 < y < z[/itex] not correct? It seems that this needs to be true in order for [itex]Y/Z[/itex] to be less than 1?
Now that I'm looking at it again, is this transformation shortcut even valid in this situation? I'm not sure if my [itex]h_1, h_2[/itex] are workable in this case.
