Blackbody Heat Shields/Metal Sheets
  • Level: Graduate
  • Thread starter sweetdreams12
    Blackbody Heat
3 replies · 5K views · last reply
sweetdreams12
A “blackbody heat shield” is used to reduce radiant heat loss in situations where standard low conductivity insulation (i.e. normal insulation) cannot be used. The shield is constructed using a set of parallel metal sheets, each with emissivity 1.0.
Explain how/why this “heat shield” works and determine how many sheets of metal are
required to reduce the heat loss to less than 20% of the unshielded value. (Hint: think
about the radiation absorbed by each sheet and how this energy will be re-radiated.)
Diagram:
Diagram of a yellow block labelled Object at 1300 K, with a yellow arrow to the left marked Unshielded radiant heat loss, and a row of parallel blue vertical lines labelled Heat shields with an ellipsis, ending in a dark red arrow to the right marked Reduced radiant heat loss.
I really need help with this xD I don't even know where to begin.
Here are some ideas:
- assume that the whole problem is 1-dimensional
- begin with 1 heat shield: Where does it receive/emit radiation?
- assuming that the environment has a temperature of ~0, calculate the temperature of that heat shield in equilibrium
ummmm I still don't get it xD
do I use the equation:
Q = mC deltaT?
