How Do You Calculate Total Energy in Blackbody Radiation?
The total energy of blackbody radiation in a volume V at temperature T can be calculated using the integral of the function f^3 / (exp(hf/K_BT) - 1) from zero to infinity. The correct substitution is x = hf / K_bT, leading to dx = h / K_bT * df. The final result for the total energy is [8pi^5V K_b T] / [15c^3], with necessary corrections to the constants involved, specifically ensuring the correct exponents for pi and k_B. The integration process confirms that the total energy is proportional to the temperature raised to the fourth power, consistent with Stefan-Boltzmann law.
  • Understanding of blackbody radiation principles
  • Familiarity with Planck's law and the constants h (Planck's constant) and k_B (Boltzmann constant)
  • Knowledge of integration techniques in calculus
  • Ability to manipulate exponential functions and substitutions in integrals
  • Study the derivation of Planck's law for blackbody radiation
  • Learn about the Stefan-Boltzmann law and its applications
  • Explore advanced integration techniques, particularly for improper integrals
  • Investigate the physical significance of the constants h and k_B in thermodynamics
Students of physics, particularly those studying thermodynamics and statistical mechanics, as well as educators and researchers interested in blackbody radiation and energy calculations.
Abdul.119
Show that the total energy of the radiation in a volume V at temperature T is
Hint:
The hint doesn't make sense to me, and those are the equation that I found to be perhaps relevant. Do I integrate the second equation? I'm not sure how to start this problem.
I think the hint is to help in integrating the second "relevant" equation, so integrating f^3 / exp(hf/K_BT)-1 from zero to infinity should equal pi^4/15?
Hint:
Yes, you need to integrate the equation for dU/df.
Make the substitution x = hf / KbT and use the Hint.
Then
x = hf / K_b T
dx = h / K_b T * df
df = K_b T / h * du
performing the integral then gives pi^4/15 * (K_b T / h)
then together with the rest of the constants it gives [8pi^5V K_b T] / [15c^3] , which doesn't look look like the final answer, did I do something wrong or are there additional steps?
Edit: Oops sorry there is a mistake in the first equation given in the problem. The pi has an exponent of 5 not 2, and the k_B has an exponent of 4 not 2.
But still I can't seem to obtain that equation, all I get is [8pi^5V K_b T] / [15c^3], the h is missing
  • · Replies 29 ·
