Blackhole breaking the speed limit of light?
The discussion centers around the nature of black holes and their gravitational effects on light, specifically questioning whether the gravitational field of a black hole can be considered to exceed the speed of light. Participants explore concepts related to general relativity, the behavior of light near black holes, and the implications of spacetime deformation.
  • Some participants argue that the gravitational field of a black hole is so strong that it can pull light in, suggesting a notion that this might imply a speed exceeding that of light.
  • Others clarify that nothing can locally exceed the speed of light, and that light's inability to escape a black hole is due to the nature of its trajectory within the deformed spacetime, not because gravity is acting faster than light.
  • A participant proposes that gravity can be understood as a deformation of spacetime, which influences the paths that light can take, particularly within the event horizon of a black hole.
  • Some responses emphasize that the gravitational field is static and does not involve any speed that could be compared to the speed of light.
  • There is mention of analogies such as the Rindler Horizon in accelerated frames, which may provide insights into the behavior of light in gravitational fields.
  • One participant points out that the logic of equating gravitational attraction with exceeding the speed of light is flawed, comparing it to light being trapped by a wall or mirror.
Participants express differing views on whether the gravitational effects of black holes can be interpreted as breaking the speed limit of light. There is no consensus on this issue, with multiple competing interpretations and explanations presented throughout the discussion.
Some arguments rely on complex concepts from general relativity and may not be fully accessible without a background in the subject. The discussion includes various assumptions about the nature of gravity and light that remain unresolved.
youshouldtry11
So, a black hole has infinite gravity that even light can't escape from it,
my question is,
the gravitational field of a black hole can even pull light into it,
then it means it is even faster than light, if not, light can escape from it.
Does this argument make any sense, please tell me! thanks
No, it doesn't!
Nothing can locally go faster than light and this means the trajectory of any particle(massive or not, so light or anything else) can only be of two special kinds(null for light and time-like for other particles). The reason nothing can get out of a black hole, is that inside a black hole particles can have no trajectory of those kinds that leads to outside the black hole.
ShayanJ said:
No, it doesn't!
Sorry for my stupidity, but can you explain in easier words,
so, light is unable to escape from a black hole because of the black hole puts light on a trajectory that doesn't allow light to escape?
From my understanding the black hole has a infinite strong gravitational force that pulls light to it once it enters the event horizon. So this proves the gravitational force of the black hole is indeed breaking the speed limit of light?
I understand that speed should not exceed the speed limit but i was trying to think of situations,
thanks
youshouldtry11 said:
Sorry for my stupidity, but can u explain in easier words,
Its ok, this is pretty advanced stuff and you don't have the background. Its not called stupidity.
To put it in a simpler way, gravity is the same as deformations of spacetime from being flat. This means that at every point of space and at any instant of time, its gravity that determines what it means to go forward in time. And actually sometimes there isn't even a unique time, but that doesn't concern us here.
A black hole changes the structure of spacetime in a way that inside its horizon, going forward in time means getting closer to the singularity. So inside the horizon of a black hole, its the definition of time to get stuck in there and get closer to the singularity.
my question is,
Your notion that a gravitational field has a speed isn't correct. The gravitational field of a black hole is static. What makes it a black hole is that its gravitational pull is so strong that even light can't escape. At its surface called event horizon light emitted there moves locally with c. There it just isn't pulled towards the singularity and just doesn't escape either.
Thread moved to the relativity forum as it is more appropriate there.
my question is,
Light moves faster than anything with a rest mass, in the sense that if you have a fair race between light and whatever else (i.e. something with rest mass) that you're racing against, the light will finish the race first. This does not mean that there aren't some race courses that even light can't finish, specifically light can not always "catch up" to something if that "something" has a head start.
So while there isn't anything that's "faster" than the light, this statement in no way implies that light can escape a black hole. It should be understood that when we say the speed of light is the limiting speed, we simply mean that nothing can beat light in a fair race. It doesn't say anything about "unfair" races.
It's a bit mathematical, but one can gain a lot of insight by studying the "Rindler Horizon" that occurs in accelerated space-ships. Using the principle of equivalence, one can make useful analogies between the behavior of light in an accelerating spaceship and the behavior of light in a gravitational field. It's helpful to read up on the "principle of equivalence" and "Einstein's elevator" to understand how an accelerating elevator can create something that looks like "gravity". I don't have any great beginner level references on the Principle of equivalence handy, and it's a bit of a digression, so I won't be more specific other than to mention it as something that could be useful to learn more about.
For an intermediate level treatment (with calculus) of the Rinlder horizon,you might try Greg Egan's treatment at http://www.gregegan.net/SCIENCE/Rindler/RindlerHorizon.html. I'm not aware of any good non-calculus beginner level treatments of the Rindler horizon, unfortunately. Wiki's treatment of the topic, for instance, seems to be at least at the same level as Egan's, and to my mind much more terse and harder to follow.
To summarize: light is the fastest thing around, but under circumstances such as the black hole event horizon, or the Rindler horizon on an accelerating space-ship, it's simply not "fast enough". Lght is the fastest thing that exists according to the laws of physics as we currently understand them, so what this means is that if light can't escape a black hole, nothing can.
There is no "gravity leaving the black hole". The apparent gravitational attration is there because spacetime is deformed. In the easiest case, the deformation is static - nothing changes, nothing moves. Nothing breaks the speed of light.
Many features of black holes can be understood graphically in Kruskal–Szekeres coordinates. Image from "Dr Greg" there:
Region I is the world outside the black hole, region II is inside the black hole. Region III and IV don't matter here. The upper hyperbola labeled "r=0" is the center of the black hole. The future is upwards, space is left/right.
Light always travels upwards parallel to one of the two orthogonal lines. It can go towards the upper left, going from region I to region II: it can enter the black hole. Light starting in region II cannot leave it and will hit the center.
Particles with mass have to travel "between" the two light directions: they have to move upwards, and sidewards slower than light. They can also enter the black hole, but cannot leave it.
The logic is flawed. Light is also trapped by a black body or a wall or a mirror, without any of those things going faster than light. They were already present when the light ran into them. Similarly the static gravitational field was already there when the light entered it. It didn't have to go faster than light, the light came to it.
thankyou for helping me out,
so the
Thankyou everyone for such kind and complete answers, appreciate it !
  • · Replies 40 ·
  • · Replies 20 ·
  • · Replies 62 ·
10K
  • · Replies 22 ·
  • · Replies 21 ·
  • · Replies 31 ·
