Boat wavelength oscillation problem
The discussion revolves around a physics problem involving a boat's oscillation and wave properties. The father and son observed 22 oscillations in 38 seconds, with each wave crest taking 13 seconds to reach land. The wavelength is twice the length of the boat, which is 20 feet, leading to a calculated wavelength of 40 feet. Participants clarified that the wave speed can be determined using the formula D = v*t, where D is the distance to shore. The final calculations suggested a distance of approximately 301 feet from the shore.
phys1618
a father and son went on a cruise that's 20 ft long. the dad observed the cruise swayed thru 22 complete oscillations in 38 s, and one wave crest pass per/oscillation. the son noticed that each crest required 13s to reach land and the wavelenght is twice the length of the cruise. how far were they from land?
velocity=wavelengh/T
velocity=wavelengh *f
for the wavelenghth I have 13.33m because i converted ft into meters. then since they nentioned that the wavelenth is twice the size of the boat.
I wanted to divide the number of complete ossiclation 22 by the 38s, but when it added that it takes 13 seconds for each crest to reach land. I got a little confused..
should i continue to do that or should i figure how many crest had hiut land already??
please help! thanks in advance.
How frequently were the wave lengths completing an oscillation?
That gives you the T for 1 oscillation.
Each wavelength is twice the length of the boat which is 20'.
So that tells you the wave velocity doesn't it?
Knowing the velocity and the time to shore, how far again is the shore?
yes, that's what i was doing until they told me that it takes 13 second to shore. I didnt know where that time to shore belongs. So i did all that and my answer came to be 299.39m. is that correct?
ThankYou LowlyPion. You have always been a great help and quick too.
thank you thank you. I appreciate it
Once you have your wave speed, then surely you know that D = v*t
Preserving more precision and noting that the dimensions used were kept in feet and not meters I get slightly more.
13*40/(38/22) = ...
yes, keeping in ft, i got 301 .. thank you so much for your help
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
