Bohr model, Why do we assume a standing wave?
In summary: You could imagine wave pulses traveling around the nucleus in a similar fashion.Yes, there are wave-like solutions to the Schrödinger equation that correspond to a free particle moving in the Coulomb potential of the nucleus. These solutions have a "wave packet" shape, which means they are a superposition of different wave numbers (or momenta) and thus correspond to a particle with some spread-out (rather than sharply defined) position and momentum. This is what you would expect for a free particle, and it can be used to describe, e.g., the spreading of a wave packet in time.It doesn't matter if the field isn't single valued because each time the wave passes a point is at a different time.Actually
kidsasd987
143
Hi, I wonder why we assume the matter wave of an electron is standing wave. Is there any reason why it has to be standing wave?Is it because standing wave is the right "wave equation solution" that satisfies integer multiple behaviour of bohr model?
Likes Klingonwarrior82
Disregarding the fact that the bohr model is wrong, the reason I've heard is that a standing wave would explain why the electron doesn't radiate EM waves and spiral down to the nucleus.
A standing wave is required so that the solution is single-valued at every point in the orbit.
Likes DuckAmuck
Thank you for your answer.
Could you specify further? I understood this way. so spatially, if we have a wave equation solution that is not a standing wave, then it would create a interfered wave when it goes one round(sum of the same wave equation with different phases which we cannot find integer related equation). And this feedback process would not give a single solution and that is absurd.
kidsasd987 said:
Could you specify further? I understood this way. so spatially, if we have a wave equation solution that is not a standing wave, then it would create a interfered wave when it goes one round. And this feedback process would not give a single solution and that is absurd.
You would get zero on average everywhere, and it would not be a stationary state.
Ah thanks!
More precisely, the wave function of a bound electron--that is, an electron that is confined in a bound state--is a standing wave (if we ignore the issues with that term--see below). We don't assume this; we derive it by solving the Schrodinger equation with an appropriate potential energy term describing how the electron is bound (for example, the Coulomb potential of the nucleus in an atom), and looking at the time-independent solutions.
Also, the term "standing wave" might be misleading, because it suggests that the bound electron is confined to, for example, a single "orbit" at a fixed radius around the nucleus in an atom. That is not the case. The wave function describing a stationary state of the bound electron in an atom is distributed in all 3 spatial dimensions, and the "nodes" of the distribution (places where the amplitude is zero) are not equally spaced as the "standing wave" analogy suggests. (So, for example, your images in the OP are not descriptions of an actual electron wave function.)
Likes vanhees71
Thank you it helped a lot!
I also want to add that you mix here models. The Bohr-Sommerfeld model is part of "old quantum theory", and it's outdated for more than 90 years now. It's interesting for historians of science to analyze how groundbreaking new insights in the natural sciences are found, but that's all that's interesting about it nowadays.
The "standing-wave picture" is part of modern non-relativistic quantum theory in its "wave-mechanics formulation" a la Schrödinger, which implies that the stationary (time-independent) states are given by the eigenstates of the Hamilton operator. The Schrödinger equation then tells you that the corresponding eigensolutions of the Hamiltonoperator just depend on time via a phase factor ##\exp(-\mathrm{i} E t/\hbar)##, and thus the probabilities, given by the modulus of the wave function squared, are indeed time-independent. That's why the stationary solutions of the Schrödinger equation are precisely the eigenstates of the Hamilton operator of the system and that these states factorize in a time-dependent phase factor (which is irrelevant for the physics content of the wave function, i.e., the probability distribution for finding the particle at a place doesn't depend on it) and a position dependent solution of the time-independent Schrödinger equation, which is just the eigenvalue equation for the Hamiltonian. These are then by definition of course standing waves.
Likes SerbianQuantum
There's no a priori reason why the wave function has to be stationary. The planetary model assumes electrons revolving around the nucleus. You could imagine wave pulses traveling around the nucleus in a similar fashion. It doesn't matter if the field isn't single valued because each time the wave passes a point is at a different time. Bohr assumed a standing wave because that's what works. The actual scientific method goes both ways. Experiment drives models that explain the results, which ideally predict more results which can be measured by experiments. Some cartoon depictions of the scientific method depict people deriving everything from scratch on a chalkboard and telling the experimentalists what the measure. Usually, it's the other way around.
Not in general, no. But if we are looking for a stationary state, i.e., a state that does not change with time, yes, it does.
And that model is wrong, so it's irrelevant here.
No, he assumed a standing wave because it happened to give a model that worked better than the classical model of "electrons revolving around the nucleus", since the latter model predicted that atoms would collapse, which is obviously wrong. But Bohr's model does not "work" in the sense of accounting for all the experimental knowledge we now have; that's why we don't use it any more.
Of course. By "it works" I meant "it works better than a model without stationary states, like the planetary model". My interpretation of the OP question is "why did Bohr assume a standing wave rather than a wave that propagates around the nucleus in a circle?" Some of the responses were begging the question. I hope the OP realizes that the Bohr model is obsolete, and wavefunctions do not look like the pictures above, and the OP was simply asking out of historical curiosity.
Actually, Bohr didn't use standing waves in his model. He assumed that the orbital angular momentum is quantized. (Actually he assumed the "action-angle integral" of the electron's motion is quantized, IIRC, which is equivalent to the orbital angular momentum in this case.)
De Broglie came up with the standing-wave idea several years later, as a way of deriving Bohr's quantization condition.
Likes vanhees71
1. What is the Bohr model and how does it work?
The Bohr model is a simplified representation of the structure of an atom, proposed by Danish physicist Niels Bohr in 1913. It depicts the electrons in an atom orbiting around the nucleus in specific energy levels. These energy levels correspond to the electron's specific distance from the nucleus. The model also explains how electrons transition between energy levels, emitting or absorbing energy in the form of photons.
2. What is the significance of the Bohr model in understanding atomic structure?
The Bohr model was a crucial step in understanding atomic structure because it provided a visual representation of how electrons behave in an atom. It also explained the spectral lines observed in the emission spectrum of elements and helped in calculating the energy levels of electrons in an atom.
3. What is a standing wave and why do we assume it in the Bohr model?
A standing wave is a type of wave that appears to be stationary, with no net transfer of energy. In the Bohr model, we assume a standing wave because it explains the stability of the electron orbits. By assuming that the electron's energy is quantized (can only exist in specific energy levels), the standing wave model can explain why electrons do not spiral into the nucleus due to electromagnetic radiation.
4. How does the Bohr model relate to modern atomic theory?
While the Bohr model was an important development in understanding atomic structure, it is no longer considered an accurate representation. Modern atomic theory, based on quantum mechanics, explains the behavior of electrons in an atom using probability distributions rather than fixed orbits. It also considers the wave-particle duality of electrons, which was not accounted for in the Bohr model.
5. Are there any limitations to the Bohr model?
Yes, the Bohr model has several limitations. It only applies to atoms with one electron, such as hydrogen, and cannot explain the behavior of multi-electron atoms. It also does not account for the uncertainty principle, which states that it is impossible to know both the position and momentum of a particle simultaneously. Additionally, the Bohr model does not explain the chemical bonding between atoms, which is essential in understanding the properties of molecules.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
