Boiling Point of Rubbing Alcohol Lab | In-Class Experiment
The lab aimed to determine the boiling point of rubbing alcohol using a Thiele tube setup, but no boiling was observed even when temperatures exceeded 93 degrees. The teacher suggested that the temperature was overshot, but this explanation was questioned, as boiling should occur once the boiling point is reached. The discussion highlighted the potential for superheating, a phenomenon where liquid does not boil despite reaching high temperatures due to a lack of nucleation sites for bubble formation. This can occur in pure liquids in smooth containers. The use of the Thiele tube was defended as it allows for better temperature control and smaller sample sizes, which can be beneficial in experiments. Concerns were raised about the safety of superheating, and the necessity of using a capillary tube to facilitate boiling was also discussed. The conversation emphasized the importance of understanding superheating and its implications in the lab setting.
UMath1
In class, we did a lab to determine the boiling point of rubbing alcohol. We used a thiele tube filled with water and place a test tube attached to a thermometer w/rubber band in it. However, we never saw any signs of boiling. We conducted several trials, the temperature went all the way above 93 degrees, but there was no sign of boiling.
Our teacher said we overshot it..but I don't think that makes sense. Even if the temperature of the water exceeded the boiling point of the alcohol, the alcohol should have begun to boil.
Also, I don't understand the point of using the water and thiele tube setup. Why not directly heat the rubbing alcohol and measure the temperature in it? The temperature will stop changing at the boiling point allowing for easy detection.
Chemistry news on Phys.org
Did you use boiling chips?
Superheating (if it happened) can be dangerous.
No we did not. Do you know why we didn't see it boil? And why not directly heat the rubbing alcohol and measure the temperature in it? The temperature will stop changing at the boiling point allowing for easy detection.
Superheating is an option. It also a reason why temperature doesn't have to stop at the boiling point.
What does that mean?
What is unclear? Did you look up superheating?
I know what it is, but how and why does it happen. And what might have been the cause in this case?
If it helps according to the procedure we were supposed to place a capillary tube in the test tube, but our teacher said that was not necessary.
Capillary tube plays exactly the same role boiling stone does.
Your teacher explanation as quoted ("you overshot") doesn't sound correct. Yes, it is possible the liquid was overheated, other than that it is not possible to miss the boiling point. Your thinking (boiling should keep the temperature "locked" at the boiling point) is right.
So what happened? Superheating? And if so why?
And what was the point of using the thiele tub setup? Why not just heat the rubbing alcohol directly in a beaker and wait till the temperature plateaus?
Think about the size of the sample required for a direct heating, compared to a sample placed in a small tube.
Any page explaining superheating will discuss why it happens. Have you read about it?
But even if a small sample is used, the temperature will still plateau. Yes I did read about it but I don't quite understand it.
How long till the small sample disappears? When using water bath changes of the temperature are much slower, which means it is much easier to control.
What do you know? Which part you don't understand?
It might take a very small unit of time, but while it is disappearing you can still read the temperature...correct?
So I read that superheating occurs when surface tension added with atmospheric pressure creates the need for greater vapor pressure. But when and why does this happen? And why in particular must it have happened in this particular lab?
Not necessarily. Thermometer doesn't react to temp changes infinitely fast, it has to be warmed up/cooled down.
Whenever there are no places on which the bubbles can start to build. So called "nucleation sites". If the liquid is pure enough, if the walls of the container are smooth enough, vapor bubbles don't build up easily enough.
To some extent it is random, sometimes it happens, sometimes it doesn't.
28K
  • · Replies 60 ·
12K
21K
21K
13K
