Boiling point on top of mount everest
The discussion revolves around determining the boiling point of water at the top of Mount Everest, which is at an elevation of 8848 meters. Participants explore the relationship between atmospheric pressure and boiling point, referencing thermodynamic principles and equations related to pressure changes with altitude.
  • Homework-related
  • One participant expresses confusion about the equation for pressure with altitude and its application to find the boiling point of water, questioning the values for molecular weight and the gas constant.
  • Another participant clarifies that P_atm refers to the pressure at sea level and that the equation is meant to compare pressure at different heights.
  • A participant inquires whether the normal boiling temperature of water (373 K) should be used in calculations.
  • Another participant seeks clarification on what temperature to input into the pressure equation.
  • One participant challenges the origin of the pressure equation and requests a reference for it.
  • A later reply introduces the concept of enthalpy of vaporization and suggests that the boiling point will be lower than 373 K due to the reduced pressure at high altitude.
  • A participant mentions that the problem is sourced from a textbook and expresses unfamiliarity with the pressure equation provided.
Participants express varying levels of understanding regarding the pressure equation and its application. There is no consensus on the correct temperature to use or the interpretation of the equation, indicating ongoing confusion and differing viewpoints.
Participants highlight limitations in their understanding of the pressure equation and its variables, as well as the need for clarity on the relationship between boiling point and vapor pressure at different altitudes.
physstudent1
At what temperature does water boil on the top of mount everest, elevation z = 8848m?
Recall that the dependence of pressure with altitude is give by:
P=P_atm * exp(-MWgz/RT)
MW=molecular weight of the gas, P_atm =atmospheric pressure, g is the gravitational acceleration.
Well I have never seen this equation before and I think misusing it is what is throwing me off int his problem. I understand that once I know the pressure of the air on Mt Everest I just need to look through the steam tables and find what Temperature the vapor pressure of water = the pressure of the air. However I am little confused on this equation. What temperature are they looking for? I'm assuming MW would be that of air which I think off hand is like 28g/mol not sure though and R is the gas constant in meters and not sure what other units to use. I also don't really know what to plug in for P_atm because I thought what we were looking for was the atmospheric pressure?! Someone please help this problem should be really easy its only the 6th problem in the first chapter of HW in my thermo book!
You use the first equation to get the pressure at the top of Everest
P_atm is the pressure at sea level - the equation is really for a difference in height so if you take z to be measured form sea level that is the pressure you are comparing to.
The variation of boiling point with altitude is a similar equation, rather than retype it - I will just give you the link. http://en.wikipedia.org/wiki/Boiling_point
Interestingly guess which mountain they use as an example!
what temperature would i put in though 373 K? (normal boiling temp of water?)
hey I understand to use the equation for pressure but I'm just confused on what Temperature to put into it can anyone help?
I don't know where the equation you posted came from but it's not obvious what temperature T refers to.
Do you have a reference for this?
In thermochemistry you need to talk about [tex]\Delta_{vap} H[/tex], "Enthalpy of Vaporization" instead of boiling point. So once you know the pressure you can use the laws of thermodynamics to calculate how much heat (q) needs to be added to make the water boil. It will be less than 373 K because that is the temperature needed to boil at sea level.
Also, read this quote from the Wikipedia link: "The boiling point corresponds to the temperature at which the vapor pressure of the liquid equals the surrounding environmental pressure."
its from a problem in my book engineering and chemical thermodynamics by milo koretsky its in a homework problem it just says remember hte equation for pressure based on altitude is : and has it but i have never seen it before.
  • · Replies 23 ·
