Boot Raspberry Pi from an iscsi target
  • Thread starter neilparker62
    Raspberry pi
Homework Helper
Education Advisor
Insights Author
TL;DR
net boot raspberry pi from scsi SAN
Just wondering if anyone having experience with scsi / iscsi can help out ?
I am trying to boot a set of raspberry pies from an iscsi target server I have set up on Linux Mint (Cinammon). The setup works fine for network booting via NFS so I think I have configured the tftp , dnsmasq and nfs side of things correctly. The raspberry pi is able to find it's boot directory and associated boot files (plus config files) and everything works fine if we root mount an NFS share.
For iscsi SAN boot, one just needs to change the config.txt file to supply the name of an iscsi enabled initramfs and the cmdline.txt file to indicate the iscsi initiator and target. The raspberry pi finds everything correctly but at some point in the booting process it needs to login to the iscsi target so as to access the iscsi connected block device (Lun). At this point it comes up with the following error:
iscsiadm: initiator reported error (15 - already exists)
I believe this is an old bug associated with iscsistart. If anyone happens to know of a fix or work around, please advise.
neilparker62 said:
TL;DR Summary: net boot raspberry pi from scsi SAN
Certainly, your situation sounds challenging. The error you're encountering (`iscsiadm: initiator reported error (15 - already exists)`) suggests there might be a conflict with existing iSCSI initiators.
Here are a few troubleshooting steps you could consider:
1. Check for Existing Connections: Verify if there are any existing iSCSI connections or sessions on your Raspberry Pi or the iSCSI target server. You can use commands like `iscsiadm -m session -P 3` to get detailed information about active sessions.
2. Initiator IQN: Ensure that the iSCSI Initiator's IQN (iSCSI Qualified Name) is unique. If multiple initiators have the same IQN, it can cause conflicts. You can modify the IQN in the iSCSI initiator configuration file.
3. Check for Residual Initiator Instances: Sometimes, even after disconnecting, there might be residual instances. Ensure you're completely disconnecting and cleaning up any previous iSCSI connections before attempting a new one.
4. Update iSCSI Initiator Tools: Ensure you're using the latest version of iSCSI initiator tools. Outdated tools might have bugs that have been fixed in newer releases.
5. Logs and Debugging: Check system logs (`/var/log/messages` or `/var/log/syslog`) for any additional error messages related to iSCSI. Increased verbosity in iSCSI logging might provide more detailed information about the error.
6. Community and Forums: Post your query in relevant tech forums or communities. Sometimes, other users might have faced similar issues and can provide valuable insights or workarounds.
7. Documentation: Review the official documentation of the iSCSI initiator software you're using. There might be specific recommendations or known issues documented there.
During the boot process, scsistart seems to login to the target successfully and shows the block device as sdb. Then tries to login again - I'm not sure why ?? Also not sure about the "power-on or device reset" which seems to occur. Belows is a screenshot from the raspberry pi during net boot. I'll also try checking the logs on the target server.
Photo of a Raspberry Pi boot console showing iscsistart log lines, with yellow underlines on the login to iqn.2018-02.tecmint.com:lun1 and on the 'Power-on or device reset occurred' and 'Initiator reported error (15 - session exists)' messages.
