Bose-Einstein numerical integration
22 replies · 4K views
TeslaPow
Want to integrate the total energy density over all photon energies between two
temperature values from 500K to 5800K, but not sure how to proceed.
Here is some examples to help:
I don't see how it would make sense physically to integrate over temperature.
In any case, you have ##N/V = C T^3## [see the last line of the solution of 40. (a)], which shouldn't be too hard to integrate :smile:
By C you mean: 8 *pi * k / (hc)^3 ?
That should be ##k^3## and you forgot the ##\Gamma(3) \zeta(3) \approx 2.40## factor.
So I also have to multiply the constant outside the integral with 2.40? What value will I use for T in the same equation on the left side if I integrate between 500K and 5500K ?
I don't understand. You said you
which I take to mean
\int_{500\ \mathrm{K}}^{5800\ \mathrm{K}} \frac{N}{V} dT
So you simply need to integrate ##T^3## with the proper constant outside the integral.
TeslaPow said:
When looking at Stefan-Boltzmann law, and how the procedure is done there,
As I said above, I do not understand what an integral over temperature physically means here. Usually one is interested in the value at a given ##T## or in the change with respect to ##T##.
TeslaPow said:
is this the equation to use if I want to find the integral between 500K and 5500K?
Not if you are interested in the energy density.
Maybe it would help to explain what physical situation you are considering?
I thought maybe that an integration was necessary on the energy density, but it seems that the Wien displacement law is used to find the peak curve and then you use Stefan Boltzmann law to integrate between wavelengths within that peak. Stefan law is the Planck radiation formula multiplied by C/4. Does this seem reasonable?
Everything comes from Planck's law, which gives the energy density of a photon gas per wavelength/frequency. Wien's displacement law is simply the maximum of that distribution. Stefan's law gives, which is indeed Planck's law multiplied by ##C/4## if you use the correct ##C##, gives you the power per unit area emitted by a blackbody.
Since you didn't say what you are trying to calculate, I cannot say more about what it is you should be considering.
Is the procedure for the numerical integration for Planck's radiation law the same for the energy density
as it is for the intensity? How is the value calculated here in b) ?
Yes.
There is no integration here, you simply plug in the values of λ and T.
DrClaude said:
Yes.
So the value for the constant outside the integral in the energy density is
8 * pi * c^(2) * h ?
It depends what you are integrating. Are you integrating over wavelength, frequency, temperature?
Wavelength, is it just using the value I wrote one thread above? What will it be for frequency and temperature?
The energy density per unit wavelength is given in your post #6
\frac{U}{V} = \frac{8 \pi h c}{\lambda^5} \frac{1}{e^{hc/\lambda kT} - 1}
so if you integrate over λ, the constant is ##8 \pi h c##.
However, if you make the substitution ##x = hc/\lambda kT##, then
\begin{align*}
\int_{\lambda_1}^{\lambda_2} \frac{U}{V} d\lambda &= \int_{\lambda_1}^{\lambda_2} \frac{8 \pi h c}{\lambda^5} \frac{1}{e^{hc/\lambda kT} - 1} d \lambda
&= -\frac{8 \pi (kT)^4}{(hc)^3} \int_{x_1}^{x_2} \frac{x^3}{e^{x} - 1} d x
\end{align*}
so the constant is ##-8 \pi (kT)^4 (hc)^{-3}##.
TeslaPow said:
So this is used for the integration?
In the second case I presented, yes. But in your post #10, problem 24(a) is calculated using a direct integration as a function of λ, as in the first case I presented.
The integration I outlined is used for temperature? What I don't understand quite is why wavelength is used in both energy density and intensity as the factor C/4 is used to convert between these.
Again, I have never seen Planck's law being integrated over temperature. I do not understand what this would mean physically. Planck's law gives the energy density of a photon gas at equilibrium , hence at a given temperature.
You can write Planck's law as a function of frequency or wavelength. How to go from energy density of a photon gas to emission from a black body is explained in statistical physics textbooks. A couple of online references that might be useful:
https://en.wikipedia.org/wiki/Stefan–Boltzmann_law#Derivation_from_Planck's_law
Lecture 25. Blackbody Radiation (Ch. 7)www.physics.rutgers.edu › ~gersh (slide 13)
Is this the right equation to use for the answer in 24 b) ?
TeslaPow said:
Last question, as for 24 b) in #10, the answer for the first intensity should be I(400nm,T) = 335289 W/m^2
https://www.wolframalpha.com/input/?i=solve(x/(4.593*10^(6))=0.073,x)
I don't understand what you are doing here. You seem to be calculating I(400nm,T) / (integral of I over all λ) instead of I(400nm,T)/I(966nm,T).
TeslaPow said:
This is correct.
Thanks for your guidance and help, learned a lot and really appreciate it. Here is a video I think you will
like,
