Boy Holds 100N Sign Against Wall: How Much Push Force?
The discussion revolves around a physics problem involving static friction and forces, specifically concerning a boy holding a 100N sign against a wall. Participants explore the relationship between the forces exerted by the boy and the wall, as well as the coefficients of static friction involved.
  • Participants question why the boy needs to exert only half of the normal force to keep the sign in place, considering the interactions between the boy, the sign, and the wall.
  • Some participants discuss the implications of varying friction coefficients and whether they affect the normal forces acting on the sign.
  • There is a consideration of how the coefficients of friction might combine and what that means for the forces involved.
  • One participant suggests that a free body diagram could clarify the forces acting on the sign.
The discussion is ongoing, with participants actively questioning assumptions and exploring different interpretations of the forces at play. Some guidance has been offered regarding the relationship between the coefficients of friction and the normal forces, but no consensus has been reached on the overall understanding of the problem.
Participants are working within the constraints of the problem as stated, including specific values for the coefficients of friction and the weight of the sign. There is an emphasis on understanding the underlying physics rather than arriving at a definitive solution.
Shindo
If the coefficient of static friction between the sighn and his hands is 0.6, and the coefficient of static friction between the sign and the wall is also 0.6, with what force must the boy push to keep the sign in place?
0.6(Fn)=100 N
Fn=166.7 N
So my question is this: Why does the boy only need to exert half of the normal force in order for the sign to stay in place?
My reasoning is this: he pushes the sign, which pushes the wall, the wall pushes against the sign with the same force that the boy is exerting. But this makes me want to think that there are two normal forces, one from the boy and the wall and one from the sign and the wall. Is this true, or is there another reason the boy pushes with only half the normal force? Thanks!
What would happen if the friction coefficients were different?
Hmm, so if one coefficient was 0.6 and the other 0.7, the net coefficient force would be 1.3.
So does that mean that there's only one normal force, but the boy is dancing with two frictions: one with him and the sign and the other with the sign and the wall? Which causes the net coefficient to be 1.2?
1.3 is not a force.
It is important to be careful in what you write. You mean the sum of the friction coefficients is 1.3.
Can you write out the general equation for the minimum applied force ##F## needed to hold the sign up in terms of the mass ##m## of the sign, the acceleration of gravity ##g##, and the two coefficients of static friction ##\mu_h## between hand and sign and ##\mu_w## between sign and wall?
Where does the "normal force" come from - what is it?
But the answer to your question is that when the coefficients of friction are the same, boy and wall contribute the same amount to the friction.
Which seems a bit like what you were trying to say.
Sure:
##F## = (##m## X ##g##)/(##\mu_h## + ##\mu_w##).
So what I'm getting is that since there are two friction coefficients, they add together?
My first thought was that the force required was equal to 100/0.6. But I'm not sure why it's half of that.
Well done - note: you don't need the "times" sign.
If ##\mu_h=\mu_w=\mu##, then $$F=\frac{1}{2}\frac{mg}{\mu}$$ ... this is the situation you had: see the 1/2?
If ##\mu_h=2\mu_w=2\mu##, then $$F=\frac{1}{3}\frac{mg}{\mu}$$ ... now the force is 1/3mu of the weight.
Oh wait - you mean: why does the kid have to supply half this force and the wall supplies half as well?
What happens when the boy and the wall do not provide the same normal force?
Maybe a free body diagram for the bloc will help you to understand better.
How may forces act on that sign? How many are up?
It just happens here that the coefficients add up. But this is not a general rule.
What you add up, in general, is forces. Here you have the same normal force on both sides of the sign (you understand why?) and this makes the coefficients to "add up".
  • · Replies 18 ·
