How Can I Account for Wind Loading in Calculating Buckling Load on a Beam?
  • Thread starter Thread starter Banana-Man
    Buckling Wind
To account for wind loading when calculating the buckling load on a beam, one must first determine the design wind speed based on local codes, often using a 50-year gust standard. The wind pressure can be calculated using Bernoulli's equation, factoring in the coefficient of drag and the projected area of the structure. Wind loading acts as a distributed load, typically applying a bending load alongside the compressive load on the beam. An analysis of the stress in the beam members should follow, incorporating a safety factor based on permissible stress values from relevant codes. Overall, understanding the interaction between wind forces and structural integrity is crucial for accurate buckling load calculations.
Banana-Man
Hi all,
I have recently been asked to calculate the Buckling load on a beam (channel) carrying pipes, (Eulers critical load) this was no problem. Then i was asked to allow for wind loading.. I can not for the life of me figure out how to do this?
Any tips for me?
Thanks in advance
Is your undergrad degree in engineering or physics? If so, wind loading is the velocity pressure (Bernoulli's equation) at the design wind speed for your area times the coefficient of drag times the projected area of whatever the wind is blowing on. Wind loading is a distributed load, and normally in the horizontal direction.
I think the wind will apply a bending load to the beam at the same time as the compressive load. Steps might be,
1) Find the design wind speed. Depending on the level of security required, it might be the once in 50 year 3 second gust. You should be able to find a code enabling you to find this for your location. Typical value is 100mph.
2) Then calculate the wind pressure and the projected area and shape/drag coefficient of the structure, (typical 40 psf in Imperial) and so find the force.
3) Find the stress in the members by analysis.
4) Allow a safety factor by finding the permissible stress in each member from a code.
5) Usually, compressive loads are the worst case.
What mathematics software should engineering students use? Is it correct that much of the engineering industry relies on MATLAB, making it the tool many graduates will encounter in professional settings? How does SageMath compare? It is a free package that supports both numerical and symbolic computation and can be installed on various platforms. Could it become more widely used because it is freely available? I am an academic who has taught engineering mathematics, and taught the...
14K
