Buffer solution + equilibrium + Organic compound
myvow
For this question,why Ka =(ch3coo-)(h+)/(ch3cooh) instead of Ka =(ch3coo +x)(x)/(ch3cooh-x) ?
Handwritten-style worked solution to a buffer pH problem: initial pH from Ka = [CH3COO-][H+]/[CH3COOH] with 1.8*10^-5 = (0.30/2.0)[H+]/(0.20/2.0), giving [H+] = 1.2*10^-5 M and pH = 4.92.
First equation uses equilibrium concentrations, second uses initial concentrations modified by the extent of the dissociation, to calculate equilibrium concentrations. Do you understand what these means?
Worked buffer problem: 0.30 mol CH3COONa and 0.20 mol CH3COOH in 2.0 L, initial pH via Ka = 1.8*10^-5 = (0.30/2.0)[H+]/(0.20/2.0), giving [H+] = 1.2*10^-5 M and pH = 4.92.
You have now modified your initial post. I do not understand what you have in mind by your x.
You might have been confused by the CH3COONa. That is a conventional formula, it really just represents the composition of sodium acetate but in aqueous solution and for that matter in crystal sodium acetate is all Na+ and CH3COO-. When you add to this "HCl" - I.e. H+ + Cl- - a fraction of the acetate ions CH3COO- become protonated to form CH3COOH and then the calculations you are asked about involve that fraction, which actually determines the pH as you can see from the given formulae.
