Engineering Building a logic circuit from a truth table
This discussion focuses on building a logic circuit from a truth table, specifically addressing the confusion around the number of AND gates required for a given output. The participants clarify that there are three inputs (A, B, C) and one output (F), leading to eight possible combinations (2^3). The solution involves using Karnaugh Maps for simplification, which resulted in four separate minterms that must be ORed together to achieve the desired output. The conversation also touches on the potential use of exclusive-OR gates, although they are not permitted in this context.
  • Understanding of logic gates: AND, OR, NOT
  • Familiarity with truth tables and their construction
  • Knowledge of Karnaugh Maps for simplification
  • Basic principles of digital logic design
  • Learn how to construct and simplify Karnaugh Maps
  • Study the application of minterms in logic circuits
  • Explore the use of exclusive-OR gates in digital logic
  • Investigate the implications of using different types of logic gates in circuit design
Students studying digital logic design, educators teaching circuit design concepts, and anyone interested in understanding the practical applications of truth tables and logic gates.
MarcL
P.S I know I am not supposed to use attachment but there are no way for me to input the table in a clean way... same for the logic circuit drawing. Would anyone mind helping me?
1. Homework Statement
AND gates require both input to be True to get a true ouput
NOT gates are just the opposite of what you input in them ( 1 -- > 0 and 0 --> 1)
OR gates require at least one input to be true to create a true output
I can't seem to understand why the answer key uses 4 AND gates with 3 output. Like the one below :
It just seems very... weird that there are only 4 a inputs where as in the truth table there are 8 inputs in the truth table. Anybody can help me understand that?
Have you drawn a Karnaugh Map for that truth table? Can you share it with us? :-)
Oh, well I know how, I just didn't try because this was a set of problems before it was taught, but I'll do that right now. ^^
There are four inputs in the truth table -- A, B, C, and F -- not eight.
Edit: Make that three inputs -- A, B, and C --and one output -- F.
So I'm guessing the first thing to do is reduce the truth table either using theorems or karnaugh map right? ( hence why you asked)... If so then I got the following
FAB 00 01 11 10
C
0 0 1 0 1
1 1 0 1 0
and then I group together if I remember correctly and that allows me to cancel the input that "changes" if the input is the same ( I don't know if I'm clear? :/). But none of them are similar.
Edit: Sorry I didn't express myself right... I meant 8 possibilities out of 3 inputs ( 2^3)
Edit2: Can't seem to format this table right ughhhh
Try using the "code" tags to preserve spaces for formatting. Like this:
Code:
A B C D
0 1 0 1
Code:
  AB      00  01  11  10
C
0          0   1   0   1
1          1   0   1   0
Thanks!
Wow, doesn't look like there are any simplifications. That's why there are 4 separate minterms that you OR together to get the output.
@MarcL Has your question now been answered?
As an aside, if you were allowed to use any gates of your choosing, you'd just need a pair of 2-input exclusive-ORs.
F = A ⊕ (B⊕C)
NascentOxygen said:
F = A ⊕ (B⊕C)
Nice! Too bad he can't use XORs. I'll remember that trick! :-)
You can do nice K map tables in Latex:$$
\begin{array}{|c|c|c|c|c|}
\hline C|AB & 00 & 01 & 11 & 10\\
\hline 0&0&1&0&1\\
\hline 1 & 1 & 0 & 1 & 0\\
\hline
\end{array}$$
Likes berkeman
  • · Replies 20 ·
