Caculate the force between to anti-parallel wires
  • Thread starter Thread starter LBP
    Force Wires
The force between two anti-parallel wires is calculated using the same fundamental principles as for parallel wires, specifically the formula F = μ0LIaIb/2∏d. However, the key distinction lies in the direction of the currents; anti-parallel currents repel each other, resulting in a negative force value compared to the attractive force of parallel currents. The magnetic field generated by one wire influences the other, and the net force can be derived by applying the Lorentz force equation, F = BIL, where B is the magnetic field strength. Understanding the right-hand rule is essential for determining the direction of the forces involved.
  • Understanding of electromagnetic theory, specifically Ampère's law
  • Familiarity with the Lorentz force equation
  • Knowledge of the right-hand rule for determining force direction
  • Basic proficiency in vector mathematics for calculating distances and forces
  • Study the derivation of the force between parallel and anti-parallel wires using Ampère's law
  • Learn about the application of the right-hand rule in electromagnetic contexts
  • Explore the implications of current direction on magnetic field interactions
  • Investigate real-world applications of wire interactions in electrical engineering
Students of physics, electrical engineers, and anyone interested in understanding electromagnetic forces between current-carrying conductors.
LBP
I am trying to figure out how the formula for the force between two anti-parallel wires differs from the formula for parallel wires.
B=μ0I/2∏R
Force between two parallel wires = μ0LIaIb/2∏d
I understand that d is the hypotenuse made by the x and y distances between the two parallel wires.
I also understand that if the two currents run in parallel they will attract, but if they run anti-parallel they will repel.
What I don't understand is how to manipulate the formula to calculate the anti-parallel force. At first I thought it would just be the negative value of the attractive force, but I am unsure. My other thought was that the repelling force would be based off of the net magnetic force between the two wires.
I am very lost. If anyone felt like clearing this up for me I would very much appreciate it.
Welcome to PF, LBP! :smile:
The anti-parallel force is just the negative value of the attractive force.
It follows from the same equation if you let one of the currents have a negative sign.
FYI, your formula for the force follows from your first formula, combined with the formula for the Lorentz force: F = B I L.
The direction of the magnetic field in the first formula and the force in the second formula, follows from applying the right hand rule twice.
Regardless of this direction, the magnitude of the force is the same in both cases.
Thank you so much! I had a quiz on this yesterday and I am pretty sure I nailed it! So thank you again!
Good! :smile:
